I find the simplest way, without heat or salt or sand etc, is to roll a couple of layers of masking tape around the 1/4" flex shaft to make it a slightly better fit into the tube. The tape only needs to be a bit longer than the bend you want to make.
Then insert it into the tube & form the bend with your thumbs & fingers, a little bit at a time while moving your pressure point backwards & forwards along the length of the curve that you want.
It works much like the bending springs we use at work to bend PVC conduits.
There are also any number of places that sell external bending springs for small tubes.
http://www.ebay.com/bhp/spring-tube-bender
a local guy here reminded me to leave the flex shaft in the tube and slide some heat shrink tube over the flex shaft to help take up the extra space in the tube .
on this FE Hull
a Chihuahua could make the trip faster )
and the flex shaft an heat shrink tubing all slide out of the brass tube LIKE BUTTER.
hated body & fender work
