Help!
  • Doug Smock
    • 5359
    Originally posted by mpvduck View Post
    Yea that weight is finished with all the gear.
    That's incredible!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • mpvduck
      • Jul 2015
      • 25
      Why is that incredible?
      • longballlumber
        • 3417
        A 44' long wood scale boat with cowling, wing set, and running hardware at 5 pounds seems almost unbelievable. 5 pounds is VERY light for a build of this type.
          No paint, giggle...
          • TRUCKPULL
            • 3293
            5lb - with - all hardware, Motor, ESC. and Batteries, ECT
            Ready to run??
            That would be the lightest build ever for a 44 inch long boat.
            Larry
              I'm guessing but I think the boat is 4 or 5 pounds
              This. I suspect his "guess" is a bit on the light side. Don't get into a feeding frenzy over this guys, the OP has more to worry about. Let's concentrate on helping him.
              With the right motor he can run 8S1P if he limits his run time. 1/8th scale racers in District 7 do it.
              • mpvduck
                • Jul 2015
                • 25
                OK cool maybe I was a little light on the weight. I thought you were going to tell me it was too heavy. I think I'm going to run a NEU 1527 1.5Y. How would I set up the batteries to get 8s1P or should I go to 10s1P as was suggested above. I don't really understand 8s1p or 10s1p. I know I must look pretty silly but I'm willing to learn.
                  • 7512
                  8S1P simply means your two 4S packs would be connected in series...giving 8S total.
                  10S1P would simply be two 5S packs connected in series (or a 6S and a 4S)
                  • mpvduck
                    • Jul 2015
                    • 25
                    Thanks I really appreciate all the help. Lesson learned I should have done this long before I started. Life is good.
                    • Doug Smock
                      • 5359
                      Good luck Mike. Post some pics and video when you get her up and running!
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
