I have one of these it is a nitro setup its pretty quick but is flighty haven't gps'ed it so don't know actual speed running a 647 prop fun to play with.
Dumas Eagle
Moonie,
Regardless of what the others are saying, looks like first class workmanship. Really nice looking boat!
Bob
I had the same tunnel. I cut out the air dams and put in a defuser. I also put 5 pounds of lead in my boat. I have had it up to 70MPH at the SAW's. I have not ran it in a long time. But this is it. I built it back when we were using Nicads. I loaded it with 36 cells back then.
I have plans to rebuild the bottom and make a big hatch to make it easier to load cells.
Weight counteracts lift, the lower weight of LoPos may work against the OP. Running the prop deep can help reduce lift too. I wonder how the OP knows the boat runs mid-70s just fine when his boat has not yet run, but regardless the hydro looks great, hope it runs to the OP's expectations.
What is the aluminum mount on the deck?Originally posted by Moonie View Post[ATTACH=CONFIG]149432[/ATTACH][ATTACH=CONFIG]149433[/ATTACH][ATTACH=CONFIG]149434[/ATTACH]
Next comes the bottom.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Canopy is done now. I don't know if I want to put sticker on or not...Gold Spilo
Thanks I was hoping to inspire you. I love real scale boats I have several.Originally posted by Moonie View PostWhoa! What a fine looking hydro. Any boat that's scale and able to do 70+ is a treat Just to see in the water. Loving the bud bro.
Op never said the eagle never been tested. Op mite have two eagles as well.Originally posted by Fluid View PostWeight counteracts lift, the lower weight of LoPos may work against the OP. Running the prop deep can help reduce lift too. I wonder how the OP knows the boat runs mid-70s just fine when his boat has not yet run, but regardless the hydro looks great, hope it runs to the OP's expectations.
.Gold Spilo
Beautiful job on the restoration Moonie.See the danger. THEN DO IT ANYWAY!!!
