ML Boatworks THX-305, 30.5" Outboard Tunnel hull design/ build
  • cybercrxt
    • 2926
    Well. some of you may have seen I have been playing around with a 38" and 50" Sport tunnel kit, and those designs are almost complete, so I decided I wanted to continue on with a 30" race FE tunnel design I have played around with for about a year. This is all new, and nothing like the last line of tunnels that PTI now owns, so this will require lots of testing, but I think its going to be a really nice layout for a small tunnel.Should be tons of room. I am working on the cowling design now, but the kit is complete and ready to build. I am not interested in doing other sizes of this tunnel, just this 30.5" FE hull is all I plan to do. To many other cool projects to work on! This is called the THX-305. Here are some 3d images of the hull kit. Enjoy, more soon, Mike
  • cybercrxt
    • 2926
    Well, here goes. I finished up in the garage last night, and pulled this kit out and worked on it till 1am. I have maybe 2 hours in it so far. Easiest tunnel build I have done. Really happy with the build so far, and cannot wait to see how it runs! Here are some pics:
    This is where I stopped last night.
    • cybercrxt
      • 2926
      Using my portable flat board, and a piece of angle aluminum, you first add the cross members, and bow block plate:
      Then start laminating your transom plates:
      3rd and final plate:
      Dry fit your middle, and outer forward to aft frames:
      • Darin Jordan
        • 9446
        Following!
        Darin E. Jordan - Renton, WA
        • cybercrxt
          • 2926
          Looks like I lost some pics, but you then dry fit your radio box side plates, and inside deck forward to aft frame, and tack them in place, then slide crossmember plate "A" into the back, and glue in place.
          Add the angled front radio box plate:
          Now glue in the steering servo mount sides:
          And the doubled servo mount top plates:
          • cybercrxt
            • 2926
            Now add the rear radio box hatch support plate:
            Pop out the top and pitch it:
            Sand the top of the transom and add the hatch deck:
            • cybercrxt
              • 2926
              Now repeat for the front hatch, and you will need to sand at an angle, the front end of the hatch recessed support to get it in place:
              Sand the top of the radio box, and finally add the radio box front lid. (Be sure to remove the center of the recessed hatch support and discard.)
              Here it is with the sponson frames tacked up. More on that later.
              • cybercrxt
                • 2926
                1/4" diameter dowels will ultimately be added in 3 locations, all the way through the hull, and they will be supported against a hoop system in the sponsons:
                The new logo!
                • cybercrxt
                  • 2926
                  Started on the sponsons, here are some pics:
                  Basswood strips added:
                  • cybercrxt
                    • 2926
                    Glue on the outer strip. The lower side lines up with the main support from from forward to aft.
                    • cybercrxt
                      • 2926
                      Very pleased with the lines on this one!
                      • cybercrxt
                        • 2926
                        Here is the cowling design I think I am going to do for this hull:
                        • cybercrxt
                          • 2926
                          Sheeting templates made for the ride surfaces and sponson decks, and u can see the little rounded rear corner, I love little detailing, haha
                          • cybercrxt
                            • 2926
                            The dowel lock loops work great keeping the sponsons square to the tunnel. You can see how well the ride pads sit on the granite board...dead square! Test fitting some recovery pads, they will be silicone on as i want to test various designs. That is one thing I never spent enough time on those with the past lineup, something Paul at PTI perfected on those hulls, so I need to do the same on this one.
                            • cybercrxt
                              • 2926
                              Got the cowling plug framing in today. Should look real nice one the mold is done.
