Thoughts on a 1/10th Classic Hydros Blaster
  • Steven Vaccaro
    Administrator
    • 8932
    I asked Doug about maybe making a Blaster kit, here is a link
    http://www.offshoreelectrics.com/pro...rod=ch-Blaster
    but in a 1/10th size.
    He said it would be about 33.5 with width of about 16.75.
    His concerns were how it would fit into rules and such. Im not very up on those things, so Im asking you guys what you think?
    Steven Vaccaro
  • cybercrxt
    • 2926
    That is not the right size for 1/10th scale tho. Too small.
    • JimClark
      • 5913
      using the numbers off the current master roster list the length would be 34.2 inches long and 16 or 16.2 wide depending on the year. The 1982 is the slightly wider hull.
      Billy Graham
      • cybercrxt
        • 2926
        Does 1/10th scale allow a full 1" +/- in length? If I remember, there was one club that does not? Mike
        • JimClark
          • 5913
          ERCU is Dimensional tolerance of plus or minus 10 percent is allowed except overall length shall be plus or minus one inch (1”).
          CT is Tolerances on the length and width of club hulls will be LENGTH PLUS OR MINUS 1 INCH and WIDTH PLUS OR MINUS 1-1/4 INCHES
          And Namba
          The true scale dimensions of any Scale Unlimited Hydroplane will be derived from
          the unlimited dimensions listed on the Scale Unlimited Hydroplane Master Hull
          Roster. Boats will measure within the following tolerances of the true scale size,
          excluding appendages.
          a. Overall Length ……………………………... ± 1 inch
          b. Beam…………………………………….……± 10%
          c. Maximum Depth……………………………...± 10%
          d. Afterplane Length (three point design)….……± 10%
          e. Tunnel Width…………………………………± 10%
          Billy Graham
          • DCam
            junior member
            • Dec 2008
            • 31
            Hi Guys
            Sorry for confusing things on dimensions. I was thinking when talking with Steven about saying 33.5 working within the 10th tolerances and also trying to get the length just under to accept LSSH as well (if I'm right on that rule of 34" or under), so it could be exact to 34,2 and it may be too big for LSSH anyway.
            And Namba
            b. Beam…………………………………….… …± 10%
            • raptor347
              • Jul 2007
              • 1177
              Originally posted by DCam View Post
              Hi Guys
              Make it just under 34". A small 1/10th is NOT too big for LSSH if the weight is kept down, I'm planning on running one next season. Just make the sponsons symmetrical with reinforcements on both for turn fin mounts.
              Brian "Snowman" Buaas
              Team Castle Creations
              NAMBA FE Chairman
              • DCam
                junior member
                • Dec 2008
                • 31
                Sounds good Brian, thanks!
                • Coug90
                  • Jan 2009
                  • 190
                  The 82 Atlas has a different hull design than the Blue Blaster too. The 82 boat was built with a spar and deeper pickle forks instead of a full deck in the front. I assume the design was an upgrade so the new boat would trap less air in front since Bill Muncey was killed in a blowover accident in the Blue Blaster in 81.
                  Mitch Dillard
                  1:10 Scale Hydroplane Enthusiast
                  hydroscalecreations.us, email:hydroscale@gmail.com
                  • DCam
                    junior member
                    • Dec 2008
                    • 31
                    What the hull would be is essentially what the picture is showing the bottom of the 12th scale hull. (the decks have not been trimmed in this pic so it looks wider).It brings up more of what my intent was when Steven started the thread. This bottom is a Finlay signature design with the sump in the middle and and side tunnels using his reverse curve where air is forced more to the afterplane. I seems to work well with the 12th hull. This is really what I wanted to find out if this bottom would pass legally in strict 10th rules, and what are the rules for hull bottoms? Whatever is said may determine how Steven would like to market this as. My thought is I wanted to make a larger version of it anyway for more battery etc space.ch-blaster_unfinished_bottom.JPG
                    • raptor347
                      • Jul 2007
                      • 1177
                      Unfortunately, the belly pan would make illegal. You're only allowed a 2.5" wide 4" long belly pan.
                      NAMBA FE Chairman
                      • DCam
                        junior member
                        • Dec 2008
                        • 31
                        Thanks for the info! Actually the belly pan alteration or elimination is a pretty easy change. It does not hang down much anyway, and probably would not affect much.
                        • JimClark
                          • 5913
                          Definately have my attention Doug I might just be on the list for one of these
                          Billy Graham
                          • nichismo
                            • Feb 2015
                            • 393
                            Despite my subconscious reminding me of the 1/10 scale extreme kit Mike sells, id definitely would snag one of these as soon as they were available without a 2nd thought :)
                            BIG BOY HYDROPLANES----My first RC boat and build project to boot: (and more content in my profile gallery!) ---- http://forums.offshoreelectrics.com/...proposed-setup
                            • leonard feeback
                              • 130
                              Those are not the correct type sponsons either. The Blue Blaster's sponsons were straight from the bottom of the hull to the running surface of the sponson, not relieved as in the picture.
