Going to be using the rcboatcompany rear wings and need some suggestions, should I make them so they are breakaway on case of a flip and how should I go about this thanks in advance for any and all suggestions
1/8 scale hydro
Tags: None
I make my vertical brackets out of either carbon fiber or aluminum sheet with the ability to thread for 6-32 nylon bolts. The bolts will shear in a blow-over situation and generally cause little if any damage to the wings. I also use nylon bolts for the wing support rods and to bolt the horizontal to the verticals.
parts 431.jpgparts 450.jpgparts 453.jpgWe are surrounded-that means we can attack in any direction
Here is how I am making the brackets for the verticals on the Lobster. I used .040" aluminum sheet, determined the length to be about 3 1/2", will give me bolt holes about 2 3/4-3" apart. The Lobster is kind of a PITA as there is not much room to tape the rear hatch as it is, but the wings have to go there. Knowing there is a 1/4" stringer in there with 1/16" ply on the outside, I measured in 5/16" and marked it. Clamped a straightedge along the line and slowly cut through with a Zona saw the length of the slot. This places the outside of the bracket against the stringer. I used a jeweler's flat file to open the slot just wide enough for the bracket, which was already bent 90 degrees at the bottom. Once I could install the bracket to fit, I marked the deck contour and bent the angle into the exposed part so set the wing angle. I opened up a few lightening holes and smaller holes to help epoxy it, will add a few to the very bottom as well. Once it is all in, I will add a short piece of 1/4" strip under the lip to add more support at the top. I'll make up some 1/16" ply squares to use for bolt mounts with 6-32 t-nuts and will only have bolt heads on the inside. When it blows over, the nylon bolts should shear and limit damage to the wings. All theory of course...........
020.jpg022.jpg033.jpgWe are surrounded-that means we can attack in any direction
