My latest Hydro project 1986 U-100 Boat
  • JimClark
    • 5902
    Restoring an older Spec hydro based on the old Dave Frank plan. Fixing it up, reinforcing it, sealing it, Putting a new hatch and cowl on it then painting it up as the 1986 U-100 Boat. Real challenging paint job appliance White with black block lettering that says BOAT.
    Billy Graham
  • JimClark
    • 5902
    Going to use a proboat 1500 KV motor, .130 Flex, Speedmaster hardware
    Billy Graham
    • JimClark
      • 5902
      Going to add aluminum plate to the turn fin and transom area to reinforce
      Billy Graham
      • JimClark
        • 5902
        Billy Graham
        • JimClark
          • 5902
          Billy Graham
          • 785boats
            Wet Track Racing
            • 3169
            I loved building this little Blaster Jim.
            I've run the 1500kv motor in it. Heaps of speed with an M645 prop.
            Had mine out last weekend for another play.
            I'm sure yours will look spectacular with such a simple paint scheme. Sometimes there is so much more in simplicity.
            Cheers.
              • 9438
              Is it for spec hydro or 1/10th scale Jim?
              • JimClark
                • 5902
                a spec hydro it measures 28.5 inches long
                Billy Graham
                • JimClark
                  • 5902
                  I have built the frame for the hatch. It now goes all the way to the bottom of the boat and is perfectly level to the deck flange. I will glue the top on and then trim the frame back after it is glued on securely to the hatch cover. This is my second try at it first one didn't come out well so try again. This one should be a great fit.
                  Billy Graham
                  • Doug Smock
                    • 5264
                    Looking good Jim.
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                      • 5660
                      Jim,
                      Looks great! Always love your builds!
                      • JimClark
                        • 5902
                        one more pic
                        Billy Graham
                        • rayzerdesigns
                          • Dec 2013
                          • 1228
                          That paint job is sweet
                          • JimClark
                            • 5902
                            It's going to be nice and easy and cheap graphics are also easy
                            Sent from my SGH-M919 using Tapatalk
                            Billy Graham
                            • JimClark
                              • 5902
                              Ok update. The cowl is almost ready to be glued on. I hhave added balsa to give a good glue surface. It is shaped and ready to glue after I seal the balsa. The hatch cover is ready for sealing and the sponsons are again covered.
                              Billy Graham
