Well I had never sprayed before and basically as a result I under anticipated the amount of primer that would be needed in finishing the job. I had about 5.5 ounces of mixed Klass Kote primer left (not accounting for the reducer being added) to finish the hull, and then spray the first coat onto the cowling and wing pieces. I added a good amount of reducer, id say by the time I was done it was at probably a 1:1:0.75 ratio of primer/catalyst/reducer and it seemed to be flowing well. Unfortunately, the paint setup I was using didnt really allow me to spray the last little bit of primer that was sitting at the bottom of the jar, so I set that aside for about a couple hours after adding some microballoons to it. It thickened up to a putty that I used to fill in any imperfections I saw, which you might see in these pictures because I havnt sanded them away yet.
I ordered some more white primer from Klass Kote, it will probably be here early next week, hopefully monday. Id say the hull is about 90% covered, and the uprights and canard are maybe 75% covered.
However I came across a problem. The reducer in the paint for some reason considerably weakened the epoxy around the aluminum wing tabs in the back of the boat! By the time the paint was dry, I noticed that the tabs had somehow "risen" much higher above the deck then their previous position. At first, I was thinking that I had used way too much bondo and other stuff around that area on the deck and the deck had lowered a bunch from the same effect... It wasnt until I actually pulled the hull down from the ceiling and had it level that I looked into the drain holes in the transom that I saw the bottom of the wing tabs suspended in air now rather than resting on the floor of the hull! And now they are stiff again (not as stiff as previously however) and the primer in that area is slightly chipped, specifically on the right side tab. What should I do??
