I am looking for an 1/8 FE boat I have decided that I would like to build the Degree boat. any one got any ideas where I can find the hull?
What to Build an 1/8 FE Degree
Check out Mike Luszcz! He has a kit that is just amazing. Website is http://www.mlboatworksrc.com/ He even has my used 1527 1.5y 850 kv that would be perfect for your boat.
You will be far better off to build a kit like from ML Boatworks than converting a 'glass hull designed for nitro over to FE. The biggest problem you will have will be fitting the batteries (room) in a hull never designed for them and re-engineering the hull to get everything water tight.- IMPBA Hall of Fame -
- IMPBA Hydro Technical Director -
They've always had cool grafix schemes :-)
