just got the Segad...
  • Rob DeAngelis
    • 296
    I just got my new segad... the finish is amazing and the lay out of the boat looks great, but the motors are tiny!!!! whats with the small motors??? i was expecting regular sized cans on these 2700 puppies???
    Lakeside entertainer
  • dana
    • Mar 2010
    • 3660
    define 'regular size'
    • Rob DeAngelis
      • 296
      ive never seen the whole can spin when you turn the props by hand... is that normal?
      • dana
        • Mar 2010
        • 3660
        They're outrunners. Yes that is normal for they type of motor. Outrunners have more torque than inrunners.
        • Rob DeAngelis
          • 296
          cool, thanks for the info... I went to the local hobby shop and got 2 lipos... one is a 5000mah 3s 20c and the other is a 5400mah 3s 20c.... can i be safe to use those in my segad? not in series of course....
          • dana
            • Mar 2010
            • 3660
            I don't know the Segad at all but you never want to use two packs of different mah rating at the same time. If you're using one pack at a time then yes they should be fine
            • dana
              • Mar 2010
              • 3660
              How is the esc set up? For running one pack?
              • Rob DeAngelis
                • 296
                even if its seperate esc's and motors?
                • Rob DeAngelis
                  • 296
                  yes.... its 2 seperate drives...
                  • dana
                    • Mar 2010
                    • 3660
                    I forgot you have a twin for a second there. Not sure bout that
                    • dana
                      • Mar 2010
                      • 3660
                      You def cannot safely run those two packs series or parallel
                      • Rob DeAngelis
                        • 296
                        even if its a 400mah diff? the dude at the shop told me that one side would die out and my boat would lean heavy on one side run wise... when the packs are at there end...
                        • dana
                          • Mar 2010
                          • 3660
                          You aren't running parallel or series if you are running two seperate motor esc setups so I can't say for sure. Someone who knows more will chime in soon enough
                          • dana
                            • Mar 2010
                            • 3660
                            As far as series and parallel, I always use the same exact mah/c rating packs. At least that's what I was taught
                            • Rob DeAngelis
                              • 296
                              thanks again man... i appreciate the help... Im just new to the whole twin thing... Ive always had single... this is my first one...
