P1 kos 35" offset rudder.
    • 5660
    #76
    Lenny, I forgot, are you still running with the stock out-runner? If so this is great, I also had temp issue, guess we talked about it. Eagerly wating for your 4s results.
    Cheers!
      • 4297
      #77
      Yes, Still stock motor.
      And I got to run it in the big lake yesterday,
      With a 1970 jet bout with a 454 big block for lot of chop and some tubing and knee boarding,
      First time for me on a knee boarding and had a blast.
        • 5660
        #78
        Sounds like you had alot of fun.
        had to work, orchestras have no concept about holidays!
          • 4297
          #79
          More money for more boat and stuff,
          Yes, But I am feeling it to day.
          When I got to the lake it was almost glass for 1/2 hour,
          Then the jet boat rolled in and one jet ski and some hooter, Now were having fun.
          • Joe007
            Joe
            • 124
            #80
            2012-06-10_23-43-19_258_edited-1-1.jpgLenny here is a picture of my boat. I just made the extension block of my rudder arm to extend the rudder back because of the longer stinger. The extension I made out of wood. Will show a picture of it mounted in the next couple of days. I am painting and clear coating it. Sent my props out fo sharpening and balancing to dasboata a member here on OSE.
              • 4297
              #81
              I would not use the extension,
              If you leave the rudder closer to the transom it will be out of the prop thrust cone.
              And give more speed and more control of turns,
              Plus If it back to far you have more torque on the transom bolts and hardware.
              That could rip the transom out, Witch would not be good.
              Look at it as a breaker bar for lug nut,
              The longer the bar the more torque you have to break the nut loose.
              The one you saw in past post did not work good,
              But look cool.
              That was Member Jesse J P1 kos mod.
              Link,http://forums.offshoreelectrics.com/...ighly-modified
              I talked to him about that mod later.
              • Joe007
                Joe
                • 124
                #82
                Lenny thanks for the info. I put the rudder arm on with out the extension I made. Will put some picture up tomorrow.
                Joe
