prop help
  • neal58cobra
    • May 2011
    • 117
    prop help
    I have a KOS P1 with a venom 2000 kv outrunner with a 120 amp seaking esc. I'm running a single 4 cell battery and was looking to upgrade to a 3 blade prop. Any help thanks.
    • 4297
    Hi
    I am running a x440/3 with the stock 2000kv motor and stock 60a esc or Seaking 60a esc,
    But I modded the setup inside and made the rudder off set to.
    I was doing some testing on this boat, And some modding.
    Hears a link.
    http://forums.offshoreelectrics.com/...-offset-rudder
    • DK535
      • Jan 2012
      • 626
      I run a x640 prop on mine
      • neal58cobra
        • May 2011
        • 117
        Do I need an adapter for running 3/16 props on this boat?
          • 4297
          Yes,
          Ose has them.
          Or up grade the stock flex shaft to a .187 3/16 shaft and coupler,
          That is what I have in mine.
            • 4297
            Link.http://www.offshoreelectrics.com/pro...?prod=ose-1030
            • neal58cobra
              • May 2011
              • 117
              Thanks! What parts will I need to convert to a flex cable for 3/16 props?
                • 4297
                Get a 187 flex cable and remove the liner so it fits well and you will need to gut the stinger for a new bushing to,
                The Hughey.187" cable and Etti 5mm/.187" collet would be less troublesome and very dependable,
                Also will need a bushing for the stinger and a prop dog and prop nut.
                Check Ose on hear or swap shop or post a WTB,
                Do a search or may be rcraceboat.com or kintecracing.com
