Venom KOS P1 Twin Outrunner Setup
  • Alfa Spirit
    • 2131
    Hi,
    I have the opportunity to buy a new hull undrilled with hatch for a very small price and I have a set of FMT outrunner motors 36 x 50mm, 1700kV Setup
  • Rumdog
    • 6453
    So, you did, or didnt buy one yet?
    http://forums.offshoreelectrics.com/...a-Ekos-P1-hull
    • Alfa Spirit
      • 2131
      Hi,
      I need a picture of the V hull from the back, thank you
      • Alfa Spirit
        • 2131
        Originally posted by Rumdog View Post
        The Venom P1 will be discontinued, hull/hatch set is no more avalaible in online shops. Only 2 or 3 pces are in stock at Venom Group shop BUT I' ve found a new Hull/Hatch Set - P1KOS, I really love that Fountain hull.
        What do you think about the setup?
        • Alfa Spirit
          • 2131
          Help! I need your advice, I don' t know the Venom KOS P1 hull
            • 4297
            What do you want to know about the hull ?
            • Alfa Spirit
              • 2131
              Hi,
              I want to know if turn fins are necessary, same question for trim tabs. Thanks
                • 5660
                I bought a used one from a member here who installed the small turn fins and trim tabs,http://www.offshoreelectrics.com/pro...d=ros-spdt-150 http://www.offshoreelectrics.com/pro...prod=ose-80060 the boat runs well with them, can't tell you how it would run w/o them, but I remember earlier version came without one of the items. Current version that is in stock has a fin/tab combo. My feeling is that for a single drive one is better off with them, but I have no knowledge with twin drive set ups. I can tell you that the in-line rudder doesn't work as well as the off set rudder that Lenny here moded himself. We had exchanged quite a bit of notes few months ago. I was going to copy his but got hopelessly distracted with new projects.
                  • 4297
                  What are your plans for the boat, Scale fun running and sport or high speed and saw runs ?
                  Hear a link on my modding so far and info with videos to,
                  Read through the info and it may help you.
                  http://forums.offshoreelectrics.com/...-offset-rudder.
                  Also member Jesse J did a over hall on one,
                  http://forums.offshoreelectrics.com/...18-P1-overhaul
                  And also did some twin setup on some scale mono a long time ago.
                  Check with him on his testing on them.
                  • Alfa Spirit
                    • 2131
                    Hello,
                    My plan is high speed, what do you think about the setup, is one 6S battery enough? I sent a PM to Jesse but no reply. The hull is on the way, so can you tell me if there is holes in the hull? I hate turn fins, if the P1 can run fine without those parts, that' s good, Thanks
                      • 4297
                      If just going straight at high speed with twins is what you want,
                      You may not need the turn fins.
                      But the boat torque roll easy if not setup right,
                      I would think two 5s packs in parallel would be safe for the setup you are thinking.
                      Not sure about if it will come predrilled, With holes.
                      Where did you buy the hull and hatch from,? Have a link.
                      • Alfa Spirit
                        • 2131
                        P1 hull + hatch are no longer available, I looked to webshops and it' s always out of stock. May be Venom will stop the P1 KOS. So I bought the P1 at Venom shop but it' s very expensive...
                        • Alfa Spirit
                          • 2131
                          I use stingers from HOR, lenght is adjustable 85mm to 105mm, very well build and not expensive 30US$ each
                          • Alfa Spirit
                            • 2131
                            I use 5S 5000mAh batteries with an other boat, do you think I can use those batteries paralel wired in the P1 KOS? Not too heavy?
                            With 5S motors take 31500 RPM and 37000 RPM with 6S
                            • Alfa Spirit
                              • 2131
                              I will run 5S setup, I think that 32000 RPM is enough for this mono P1 hull. Small metal propellers are available at MHZ for 3/16'' shafts, normal and reverse rotation
