Bought a Ekos P1 hull
  • Joe007
    Joe
    • 139
    I need some help, I bought a new ekos P1 vee hull. I need some measurements of some of the stock hardware. The stinger length and the length of the rudder and rudder bracket. And help would be appreciated.
    Joe
  • Alfa Spirit
    • 2183
    The stinger lenght is 1/10 of hull lenght, Speedmaster stinger strut is ok, for 3/16 propeller shafts http://www.offshoreelectrics.com/pro...os-stinger-str
    This Speedmaster rudder is perfect http://www.offshoreelectrics.com/pro...prod=ose-80050
    Use a 3/16" flexcable http://www.offshoreelectrics.com/pro...?prod=ose-1190
    What kind of setup for this hull? 4S or 6S? I think the Venom KOS P1 must be reinforced with carbon layer
    • Joe007
      Joe
      • 139
      Thanks for the info
        Hi,
        Welcome to the club,
        I have bin adding info to this thread so it will be easy to find later on in one place.
        Hears some info and ideas on this boat.http://forums.offshoreelectrics.com/...-offset-rudder.
        • Joe007
          Joe
          • 139
          Thanks Jenny but first I have to find out what the stock distance from the transom to the leading edge of the rudder is?
          • Alfa Spirit
            • 2183
            Why? If you choose the correct hardware for a 35", forget this stock hardware
            • Joe007
              Joe
              • 139
              alfa I am in the dark on this rudder and stinger setup? Should I go with a longer or shorter rudder bracket? For a motor I am thinking of the turnigy outrunner 1600k. I also want to go with the panio wire drive, what do you think?
              • Alfa Spirit
                • 2183
                Piano wire is for small boats, I give you the answer : 3/16" flex and drive shaft. I don't know this Turnigy motor, consider Leopard motors, 4082 1450kV is a very good choice
                  Ok, Stock stinger 2"3/4 off transit, And rudder leading edge to transit is 4"1/8.
                  Did you look and read the link info on motors and mounts ?
                  I am running .187 flex with modded stock stinger and stock 2000kv outrunner on 4s.
                    The boat hull is 31"1/2 long and 7"wide,
                    It can not handle to much motor or prop with out torque rolling all the time.
                    • Joe007
                      Joe
                      • 139
                      Lenny thank you for the stock measurements.
                      Joe
                      • Joe007
                        Joe
                        • 139
                        Just applied another laye of fibeglass to the inside hull. Gotta let it cure fo the next couple of days. I have to add just a little more fg to the inside nose. I am going to use a thicker piece of fg to put up in the front hull to add some weight to the nose.
                        • Alfa Spirit
                          • 2183
                          I put an order for a P1 KOS hull undrilled and its canopy, 150 €uros shipping to France included. I want to use a set of outrunner motors 500 class 1700kV. One 6S battery, two Seaking 120A and two FMT 3650 1700kV motors
