Would this be a direct replacement motor?
    I think FighterCat57 sells them now.... 2200kv that is.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      Yep!
      Have them 2200, 1600 and 1300. Very cool that they fit in this motor mount. =)
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        OK Special Offer, just so happens I have an open order with the factory and can add more to it but only today and possibly tomorrow. It will take a week or so for them to come in.
        This should be a good way to test the paypal cart feature.
        Here's where to order:
        PM or email me with any issues. There's also a contact on the link.
        This is not an OSE stocked item, so there is no conflict of interest.
        • martin
          • 2881
          Hi what is the difference between between the Turnigy red anodised range of motors & the Turnigy Typhoon range. Martin.
          • jamespl
            • 748
            In terms of fitting the p1 motor clamp I don't think the typhoon will fit because it doesn't have the lip a the bottom for the motor to clamp in.
            • martin
              • 2881
              I know their completely different in terms of outer body shape & different cooling fan but was asking in general are these 2 ranges of motors different internally or are they basically the same motors that can both be used in boats. As i use the smaller size outrunner motors in some boats & have a Turnigy Typhoon 2218H motor but was also looking at the red anodised motors & was interested in what the difference was between the 2 ranges. It really needs some one that uses/ sells both range of these motors to know the differencecs in these motors though. Martin.
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                The Typhoon's are stamped casings and have 16 gauge lead wires, rated for 22 amps. The Turnigy 3126 is a Suppo Model motor rated at 1500 watts. A much better motor at a far less cost. I've owned them both and the Suppo is hands down a better built motor. HK has them in 1600/1300 and I have them in 2200kv/Black casing.
                • martin
                  • 2881
                  Many thanks for clearing that one up on the differencies of the 2 motor ranges, The motor sizes im looking at are the smaller 450 H 2218 3200kv & 3550kv ( red anodised ) & also the 450 Typhoons. I already have the Typhoon 450H 3450kv but also wont to try the red anodised ones as well so wanted to make sure their was a difference between the 2. Yes the wires on the Typhoon motor are very thin which did raise concerns as soon as i saw them. These motors are being used in micro mono hulls by the way so will be also getting the red anodised motors to try. Im in the UK so the red motors seem a little harder to get than the Typhoons. Martin.
                  • jamespl
                    • 748
                    I'm in the UK also. Get them from hobbyking's german warehouse. They only do the 1300kv and 1600kv though.
                    • martin
                      • 2881
                      Is it straight foward registering with Hobbyking & are the reliable, Do you actually have to go into their German warehouse when you buy or will it automatically take you their if your in Europe. Martin.
                      • jamespl
                        • 748
                        Yep no probs with hobbyking, also you can use paypal. When I ordered my motor they were out of stock in the german warehouse so I ordered it from the one in china, took about 2 weeks. When you look at stuff on their website it will say DE warehouse, that means it's from Germany. Hope this helps, plus they have a good price on lipos.
                        • martin
                          • 2881
                          The 1300kv & 1600kv that they list in Germany are the 500 series motors, The ones im interested in are the smaller 450 series 3200kv-3500kv to which it looks like they dont have stock in Germany. So it looks like its off to Ebay Germany or USA . Martin.
                          • martin
                            • 2881
                            Was their any reason you went to their Japan site or did they direct you to them when you ordered, Dosnt it put the prices up quite a bit being shipped all that way as well.Martin.
                            • jamespl
                              • 748
                              They have the 450 versions. It will most certainly be cheaper from hobbyking you will just have to wait longer for it.
                              http://www.hobbyking.com/hobbyking/s...dProduct=11173
                              http://www.hobbyking.com/hobbyking/s...dProduct=11172
                              They are $11.00 dollars each, plus shipping so I bet your only looting at £18 max delivered.
                              • jamespl
                                • 748
                                I couldn't be bothered to wait for them to get stock in the german warehouse, shipping was about $13 so only around £8-£9 with the exchange rate
