NUE Power on 4S
  • JEDNJONES
    • Apr 2010
    • 134
    Originally posted by hobie View Post
    Jerry, I ended up making my drive into a pretzel!! And I was only running 4s. I took a cable from a .130 flex system, soldered the end, filed it down to fit in the stock drive end. Also was able to use a small piece of teflon as well, up on the motor side. Had to solder and file the coupler side as well.
    Not sure how it's going to work, haven't run it since that conversion. As soon as I do, I will post my results.
    It looks like it will work well, but since it's not much bigger than the stock flex, it might not hold up much better. But I didn't want to have to rebuild the whole drive as of yet. Maybe over the winter.... Lol
    That sounds like another option as well. Thanks for letting me know. I am trying to find the correct wire drive parts to order but, im having a hard time finding the longer cable length...so, .130 may be another choice.
    Jerry
    Fountain KOS P1, Formula Fastech, 37 Fightercat Daytona CF twin
    Pulled by Slash 4x4 tow vehical
    • forescott
      Hopelessly Addicted to RC
      • 2686
      I'm working on getting a wire drive for the p-1 as well. Same drive as the ekos, just longer wire. And Jeff has the 5mm to .062 couplers.
      • JEDNJONES
        • Apr 2010
        • 134
        When you figure out what parts to order, please let me know.
        Thanks
        • 996TURBO
          • 91
          54 mph is mighty fast on 4s. You have that boat dialed in
          • JEDNJONES
            • Apr 2010
            • 134
            Thanks. She runs pretty good but, its down for awhile. The 4mm cable didnt hold up. I heard your building a cat to run next year at the Northern MI RC Kilo runs...is that true?
            Had fun runnin with ya this year at the mini poker run.
            Jerry
            • Jesse J
              scale FE enthusiast
              • 7241
              Ya, I don't think they had us in mind when they opted for 1/8" flex... I bet Jeff could make a .150 flex that stepped down to 4mm for the strut, or wire drive, I am sure he could do 4mm on that. I would feel better about .078" wire, as I have snapped the .062 before on high power/load situations. You could even go .098 for some beef - as long as your tube is low curve.
              "Look good doin' it"
              See the fleet
              • JEDNJONES
                • Apr 2010
                • 134
                Yea, Ive emailed Jeff my specs and hes supposed to put somthing together for me. Ive just missed out on running it the last 3 weeks. The .150 / 4mm sounds like a good idea. I am not opposed to a whole new flex/stinger/rudder system. If I can find somthing that looks scale. I need somthing before my lake freezes too.
                • forescott
                  • 2686
                  I just got .062 wire drive w/4mm shaft and an octura 5mm to .062 hex collet for the p-1. .062 wire has held up so far on my ekos running x442 props, so I would think it would be ok on the p-1 as well.
                  • Jesse J
                    scale FE enthusiast
                    • 7241
                    Keep in mind that the power systems in twins work much less than single motor set ups. It could be a good set up though. I will be interested to see how you like it.
                    See the fleet
                    • forescott
                      • 2686
                      I just figured its turning the same prop, and at less rpm than my ekos. I would have ordered larger wire, but I don't think .078 wire fits in a 4mm shaft. We'll see if it stays together!!
                      • JEDNJONES
                        • Apr 2010
                        • 134
                        Where did you get a longer wire setup for the P1 Scott? You only sold your hatch, Not your whole boat right?
                        • Jesse J
                          scale FE enthusiast
                          • 7241
                          well, .125" flex fits, so .078" wire would have to. If you stay with 42mm and smaller props, you probably be fine. Might run some plastic props at first.
                          Actually, I broke mine because I was not absolutely in line motor-stuffing and was invoking a bit of a pressure point.
                          See the fleet
                          • JEDNJONES
                            • Apr 2010
                            • 134
                            Jesse, Do you have anything laying around that would get my boat back in the water?
                            • forescott
                              • 2686
                              Jeff Wholt @ rcraceboat.com. You have to send him a PM to get the longer length wire.
                              • forescott
                                • 2686
                                Mine lines up horribly as well. Been trying to shim and grind the mount to straighten it and lower it at the same time!
