Turn fins installed (pics)
  • jamespl
    • 748
    i got my turn fins today and installed them, i think they look pretty smart lets just hope they do the job now!
  • Rumdog
    • 6667
    You need to install them so they are perpendicular to the bottom of the hull. When the boat banks to one side in a turn, you want the fin straight down in the water, or it will cause lift and may make it turn worse. So, bracket at the same angle as the trim tab bracket.
    • Chilli
      • 3204
      What Ryan said. You want the fins perpenducular to the water's surface when the hull is leaning into the turn.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • bwells
        • Jan 2009
        • 847
        Should the fins extend below the Vee or even with it? Don't mean to interrupt!
        • jamespl
          • 748
          I wasn't sure how to angle them, should of asked first. I have just taken the boat for a run and with the strut angled down slightly and the batteries in the middle rather than side by side the boat runs much more smoothly and the turn fins have really made a difference even if they ate angled wrong but to be honest it handled that bad that anything would help. I'm only a sport boater so I will leave them as they are for now. I'm constantly learning and i have found that even small adjustments can make a big difference in a good or bad way.
          • Chilli
            • 3204
            James, As long as your happy how the boat runs, thats cool. You never stop learning in this hobby.
            Brian, Ideally you want as much of the the turn fin out of the water as possible when the boat is running straight because a fin in the water when you don't need it creates drag. The fins job is to keep the stern from sliding or spinning out in a sharp turn. So you need to find that balance between the fin doing it's job in the turn without slowing you down in the straights. Obviously for sport boating it's not as big a deal.
            Here is a pic of the transom of my gas boat whe I was building it. Obvioulsy the deeper the V, the easier it is to keep the fins out of the water.
            Mike Chirillo
            • jamespl
              • 748
              I might just bend the fin itself slightly rather than drilling more holes in the hull to bring them into a slightly better position.
              • JEDNJONES
                • Apr 2010
                • 140
                Those look very good on your P1. Good job.
                Fountain KOS P1, Formula Fastech, 37 Fightercat Daytona CF twin
                Pulled by Slash 4x4 tow vehical
                • forescott
                  Hopelessly Addicted to RC
                  • 3009
                  Are those the small or medium fins??
                  • jamespl
                    • 748
                    Small. 52mm I think they are. Any bigger would be to big I think.
                    • Skullcracken
                      • 728
                      Hows it running?
                      [QUOTE=jamespl;237416]i got my turn fins today and installed them, i think they look pretty smart lets just hope they do the job now!
                      How is yours running with two batteries. I am using one 4s and its tail heavy. Ive lowered the strut angle but I still have issues with coming out of the water. You?
                      • jamespl
                        • 748
                        With the batteries in the position on the pics it was a bit tail heavy so I put one battery on top of the other and put them in the middle so basically flipped them 90deg and it ran so much better.
                        • JEDNJONES
                          • Apr 2010
                          • 140
                          Or, you can cut out the small wood section holding the ESC and run the batts along the sides of the motor. Here is my setup....much more stable now.
                          Jerry
                          • wparsons
                            • 461
                            Chances of bending them totally straight without distorting the angle on them is pretty slim. I'd rather change the holes than try to bend it.
                            If you are moving them, you'll want them to be inboard a little bit too.
                            Light travels faster than sound, so people may appear to be bright until you hear them speak.
                            • forescott
                              • 3009
                              Got a pair of small turn fins on flea-bay for 8-bucks! They look really nice!
