King Of Shaves C1 Brushless!
  • Bug777
    • Jun 2010
    • 98
    #541
    I feel your pain mate. Took mine for a run last weekend & lost a flex shaft in 4m of water. This has been the most expensive rc i have ever had with the least amount of run time & to top it off 1 of my Turnigy packs has puffed up after 2 uses & H/K won't replace it. I have sent them pics & the postal service won't take it because it could blow up, so i don't get any help off them because they want it back.
    • dano1
      • Dec 2010
      • 403
      #542
      guess i need to reprogram my kos for 3s, have it set for 2s nows...but im hard of hearing and cant hear this sucker beep beep, my hobby shop guys had trouble hearing it too, im gonna be running 32mm props....should be interesting
      • JPriami
        N4FOX
        • 1675
        #543
        What motors are you running?
        • dano1
          • Dec 2010
          • 403
          #544
          stock motors for now, thinking of running fiego later....dont mess with it??? guy that programmed esc again had issue hearing the left esc during program....kinda has me spooked because when i purchaced the boat used the left engine was falling off line during bench tests .......lost program somehow but is online again now and set for 2s for 4 total
          • JPriami
            N4FOX
            • 1675
            #545
            I was just curious. The feiagos are good in these. I'm running 9xls in my saga hull.
              • 9438
              #546
              Leopard or Tacon 4 pole motors would be nicer than Feigao's in this. They have nice ones in 28mm x 60mm.
              I have a pair of 5050 kv's for a Drifter S build. They also have 2550 kv @ hobbypartz.com either are about $46 each on sale. 1200 watts each. Check Feigao specs for their 380xl motors, 1/2 the watts or so only....
                • 9438
                #547
                Feigao:
                This 380xl Sized Feigao Motor is 67mm in Length.
                Motor Specs:
                4-8 NiMH or 2s to 3s Lipo cells in a Mini monos or Mini hydros in the 17-22" or so range.
                440 Watts Maximum with proper cooling.
                27.6mm dia x 67mm long
                1/8" OutPut Shaft
                7.2 Ounces
                Aluminum Purple Anodized Casing
                2-Pole Neo Magnets & Compressed Windings
                Motor mount screw spacing is both 16mm and 19mm.
                3mm motor mounting screws.
                OSE recommended rpm range of 17,000 to 35,000
                Leopard:
                • dano1
                  • Dec 2010
                  • 403
                  #548
                  hows the saga perform with that set up?
                  • dano1
                    • Dec 2010
                    • 403
                    #549
                    been looking at the leapords for all my fleet, but the fiegos seem to be all i want to push thru this hull, dont wanna blw her over just yet, what do think of the 32mm props? what kind of speeds on stock with 2s for 4 total
                    • JPriami
                      N4FOX
                      • 1675
                      #550
                      ray schrauwen those spec for the leopard you posted are for a 5050Kv motor? thats way too much dont you think?
                      • dano1
                        • Dec 2010
                        • 403
                        #551
                        I just want a twin to run good and have some decent run times, if i wanna make fast blasts ...i'll run the genesis....now thats a fun boat to play with :)
                        • JPriami
                          N4FOX
                          • 1675
                          #552
                          Runs great. I can run 3S or 4S and i dont have any problems.
                          • dano1
                            • Dec 2010
                            • 403
                            #553
                            what type of speeds ya getting?
                            • JPriami
                              N4FOX
                              • 1675
                              #554
                              9xl's/11.1v lipo/40mm = 46 MPH
                              9xl's/14.8v lipo/40mm = 62 MPH
                              Im wanting to get a genesis hull at some point.
                              • dano1
                                • Dec 2010
                                • 403
                                #555
                                This kos has the kentic rudder and newer adjustable prop stingers installed, waiting on the prop shaft collars to keep the props on in case of a collar backing off....if thats what there called...lol
