King Of Shaves C1 Brushless!
  • Igoreski
    • Apr 2010
    • 77
    #466
    Tools
    http://www3.towerhobbies.com/cgi-bin...&I=LXL462&P=ML I use the ball ended allen wrenches and I made a special tool out of a micro ratchet for 1/4 hex bits and took a #25 torx bit and ground it into a 2.5mm hex.This allows about 4 to 6 clicks of the micro ratchet good for breaking it loose and for final tightness.To start the screws I put them into a chunk of small fuel or water hose,put them in the hole and once the threads are started I spin the hose until the screw is tight and the hose falls off all by itself.
    • forescott
      Hopelessly Addicted to RC
      • 2686
      #467
      Originally posted by Igoreski View Post
      I just ordered 2 sets of CF 40mm from OSE and will mod 1 set for testing.What were your favorite props.I am trying to get some Octura 442s custom shaped so they don't overload the motors but no one has them in stock.
      Funny, I am doing the same with the 442's. Having them de-tounged to decrease motor load. The cf-40's are awesome on the 9xl's with 4s. But the 9xl needs a bit bigger prop to get the speed. I loved the 32mm venom props when I had my ammo 2700's in the ekos. But it was a much shorter can than the feigao xl and not as much torque, so the little props really allowed the 2700's to reach their potential. I think you will like the cf-40's on 3s. I used them on my ammo motors on 3s and got about 37mph with them. I'm sure your 8xl's will push the same props into the lower 40's. The only thing I dont like about the cf-40's is that the hub of the prop is slightly larger than the drive dog and stinger, so they aren't streamline with the stinger and drive dog. You'll see what I mean when you put them on. It doesn't seem to affect the performance though. But that is why I am trying out the de-tounged x442's. Overall I like the performance of a 2-blade prop over a 3-blade. You can get away with a larger diameter 2-blade because they load the motors less than a 3, and I think they balance better and have less resistance through the water. Thats my 2-cents!!
      • Igoreski
        • Apr 2010
        • 77
        #468
        Props.
        Thanks for the great info,I will order a set of x442s when they come back in stock.I will try to get one of the shops to service the props for me.I just got my data logger today and I will test it on my big helicopter today before I install all the parts in the EKOS.I have been getting away with a 18amp ESC on a 20amp motor for months and I will finally see what amp load I am drawing.The Eagle tree stuff is tiny and light,with gps and all the sensors it probably weighs about an ounce.Hope it works good.
        • forescott
          • 2686
          #469
          Take a look on the forum under products and services for username "eggneg" He provides excellent prop service at a reasonable price. If you want a nice set of props, he is the guy! He can also de-tounge your 442's to reduce motor load. I had him sharpen/balance/polish a couple of props for me and they are awesome!
          • forescott
            • 2686
            #470
            Originally posted by Jeff Wohlt View Post
            I will probably order some but I have a lone a slightly smaller cable as well.
            Jeff, did you get my pm about swapping the collets you sent me for same collets with 1/8" motor shaft hole for feigao 380xl??
            • Jeff Wohlt
              • 2716
              #471
              Not sure...I need your real name. I did add the select feature on the ekos page now on my site so folks can make a choice.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • forescott
                • 2686
                #472
                PM sent.
                • Jeff Wohlt
                  • 2716
                  #473
                  Got it. I sent one back to you.
                  www.rcraceboat.com
                  • C-Mac
                    • Apr 2010
                    • 39
                    #474
                    Is there a Feigao or Ammo brushless that is a good replacement motor using the stock venom 60a ESC's? If so would you be so kind as to post links? Thanks for all the help.
                    • forescott
                      • 2686
                      #475
                      Feigao 380-10L, or ammo 28-45-2700. The feigao is on ose's site, and the ammo's are on e-bay. Both will work with the stock esc's.
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        #476
                        Originally posted by forescott View Post
                        Feigao 380-8l, or ammo 28-45-2700. The feigao is on ose's site, and the ammo's are on e-bay. Both will work with the stock esc's.
                        8l? That's a whole lot of KV, maybe a 10l. 9xl prob the best choice for stock 60amps. I don't own the boat though so i maybe wrong lol...
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          #477
                          hahahaha you edited your comment when I posted
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • forescott
                            • 2686
                            #478
                            soory, my bad! Too many numbers in my head!!
                            • C-Mac
                              • Apr 2010
                              • 39
                              #479
                              Thanks Forescott. How do the ammo 28-45-2700 compare to the stock Venom motors, are they faster?
                              • C-Mac
                                • Apr 2010
                                • 39
                                #480
                                Oh and what cooling jackets do you use with those Ammo motors?
