King Of Shaves C1 Brushless!
  • cogwheel1
    • 45
    #421
    We run the recommended aluminums--dont recall the number, but will post later.
    For a shaft saver, just use an r/c wheel collar. hole in collar must be tight or will be a balance issue.
    • cogwheel1
      • 45
      #422
      The props are Venom aluminum 36X1.4 3 blade, obviously a rt and lh rotation, but they are out of them!
        • 9479
        #423
        [QUOTE=cogwheel1;153885]The props are Venom aluminum 36X1.4 3 blade, obviously a rt and lh rotation, but they are out of them![/QUOTE]
        welcome to venom!
        • bill1473
          • Jan 2010
          • 46
          #424
          hey guys, since i hear venom has nothing in stock, what companies can i look up to find the best lipos and charger
          • Rumdog
            • 6453
            #425
              • 9479
              #426
              great choice Rumdog!
              • bill1473
                • Jan 2010
                • 46
                #427
                how the heck do u program the esc?? any tricks or advice
                • 6S HYDRO
                  • 1320
                  #428
                  what is a rc wheel collar- never heard that term
                  • Drag Boat Bob
                    • Apr 2009
                    • 304
                    #429
                    I'm sure you have seen these: (holds aircraft wheels on)
                    http://www3.towerhobbies.com/cgi-bin...?&I=LXD833&P=7
                    I'm not taking any chances of losing a shaft...
                    • Alfa Spirit
                      • 2131
                      #430
                      Have a look to http://kintecracing.com/ for upgrade parts
                      • sfcoffee
                        • Feb 2010
                        • 13
                        #431
                        An external bec will make things easier on the esc(s)I Know it makes a huge differance in my heli's esc went from hot to warm..
                          • 9479
                          #432
                          my guess is because you have more than one servo..
                          less amps going throught the bec side of the esc in a boat
                          • sfcoffee
                            • Feb 2010
                            • 13
                            #433
                            4 srevos and a gyro ,Justa little off topic.. Adding more cells is tough on the internal bec..
                            • Fredcoen
                              • Mar 2010
                              • 2
                              #434
                              some questions about my minicat
                              Hello everybody.
                              This is a copy of an email i sent to one of you a few days ago. He didn't answer so i taught maybe i could ask the forum if someone has some info for me..
                              I just bought the minicat EP 820
                              i made a first run this morning with everything from the box and two 3s 2200 mha.
                              first i lost a shaft and the blade wich was with it because the screws where a little loose.
                              the good thing was that my colleague had also his boat so i could use his shaft to test my boat.
                              some questions appear.
                              is there a better system to connect the engines to the blades instead of those strange bending shafts?
                              there is quite a bit of water inside the boat after every run. even whit tape around the "canopy" where is that water coming from?
                              do you adjust a low voltage cutoff to the esc because it appears that one battery is always depleted before the other so the remaining voltage is quite low and i don't want to destroy my batteries.
                              apart from that this boat is impressive and very stable it's lovely
                              I would be very grateful if you could give me some advices i'm more an airplane and heli pilot than a boat "driver??"
                              thanks a lot in advance
                              Fred
                              After reading carefully the entire thread around this boat i found some info but still if someone would be kind enough i would appreciate some help
                              • Fredcoen
                                • Mar 2010
                                • 2
                                #435
                                next question
                                is the stock ESC certified tu use 4S cells ? cause apparently on mine its written 2s-3s
                                can you confirme you use 36mm tri-blades with 3s and 32mm tri-blades with 4s ?
                                muchos gracias :)
