King Of Shaves C1 Brushless!
  • 6S HYDRO
    • 1325
    #331
    100.00 bucks for a set of props, but the red is sick
    • RCprince
      • Jul 2007
      • 1684
      #332
      There seems to be a discrepancy on your page(Venom) they have the Aluminum props as the pro machined and the red ones as the cast aluminum.
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • 6S HYDRO
        • 1325
        #333
        everybody hurry up and order the red ones for 15 bucks
          • 9481
          #334
          I don't see that they are in stock..
          • Akoni
            • Sep 2009
            • 41
            #335
            Interesting. Chris what are the Venom recommended batteries for each of the two different diameters? Also, how well balanced are the CNC props as they come?
            • Ub Hauled
              • 3051
              #336
              I have a few of the CNC props, not by Venom but a different brand, if the programming is done right, the props are very well balanced, sharp and very light.
              • Chris Nicastro
                • Sep 2009
                • 84
                #337
                The prices are reversed, that will be corrected today.
                The smaller 32mm diameter props would be for 5-6S and the 36mm for 3-4S. Thats conservative but will work.
                We expect them in October.
                VENOM RACING R&D
                • Steven Vaccaro
                  Administrator
                  • 8932
                  #338
                  Originally posted by Chris Nicastro View Post
                  VENOM GROUP
                  Available October, Venom™ Pro Machined and Cast Aluminum Props for the EKOS
                  Designed for those looking to get the most out of their Venom Electric King of Shaves R/C Boat,
                  Venom is proud to release their new line of Aluminum Props. For the ultimate setup, the Pro
                  Machined props are precision CNC machined in aluminum and then anodized in an attractive red.
                  For those on more of a budget but still looking for the strength and durability of an aluminum prop
                  the cast aluminum props are a perfect option.
                  Part # Description *Retail Price
                  VEN-1989 Pro Machined Prop 32mm 1.4P RT- EKOS $49.99
                  VEN-1990 Pro Machined Prop 32mm 1.4P LT- EKOS $49.99
                  VEN-1991 Pro Machined Prop 36mm 1.4P RT- EKOS $49.99
                  VEN-1992 Pro Machined Prop 36mm 1.4P LT- EKOS $49.99
                  VEN-1993 Alum Prop 32mm 1.4P RT - EKOS $21.99
                  VEN-1994 Alum Prop 32mm 1.4P LT - EKOS $21.99
                  VEN-1995 Alum Prop 36mm 1.4P RT - EKOS $21.99
                  VEN-1996 Alum Prop 36mm 1.4P LT - EKOS $21.99
                  *Note: Retail Prices are for US Customers Only
                  Venom products can be found at hobby shops throughout the U.S. and over forty-five countries worldwide.
                  For more information, visit Venom online at: www.venom-group.com.
                  For more information contact Venom directly at 800-705-0620 or email us at sales@venom-group.com.
                  Chris, nice stuff. Can you make a copy of this in the new Venom Q & A section. It will end up getting lost in this tread. Thanks
                  Steven Vaccaro
                  • 6S HYDRO
                    • 1325
                    #339
                    5-6s holy cow, so venom encourages running that high of voltage on these?
                      • 9481
                      #340
                      Wow! 6s on a 2880kv motor... gusto rpms!
                      • Chris Nicastro
                        • Sep 2009
                        • 84
                        #341
                        No you have to read the previous posts. I have suggested that if your going to run high voltage that you consider replacing the motors with lower KV units to balance out the system's amp draw. That in conjunction with smaller metal props will help tune the set up and you will reach speeds over 50mph.
                        Beyond the stock EKOS boat and 3S or 4S you really need to know boats and set ups so you dont burn up equipment. We think its a great boat to learn with because it has a lot of potential and its very stable at high speeds.
                        VENOM RACING R&D
                          • 9481
                          #342
                          dude, I don't see where you said replace the motors to run 6s?
                          If you were to go with a kv of say 1900, then that motor would run the same rpm as the stock motor on 4s.. Or a 1400kv motor on 6s would run similar rpm as the stock motor on 3s, so the 36mm props should would work just fine on that 1400kv motor..?
                            • 9481
                            #343
                            I think we are all aware of what happens when you over load brushless motors and escs..
                            a lot of smart builders on this site..
                            • Jeff Wohlt
                              • 2740
                              #344
                              Chris has been VERY forthcoming with info and a very new boat.
                              If we are that good of builders...and we are... then common sense and the rest when dealing with set ups should not be so dang hard.
                              Watching this one and some over on RC Universe makes me think these boats are $3,000!
                              Sorry to rant and a big thanks to Venom boys for continually stopping by and addressing questions. There service alone has me sold just watching this thread.
                              www.rcraceboat.com
                              jwohlt5362@yahoo.com
                              • Ub Hauled
                                • 3051
                                #345
                                well said Jeff...
