ya thats what i thought but how long did you run it dragboat? if it burnt up the wires on 3s like that, i cant imagine being able to run very long on 4s without the wires melting.
King Of Shaves C1 Brushless!
From what I heard, one of the cooling tubes was kinked under the motor, so the motor over heated.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
There were no kinks in the water tubing. See my post #185:Originally posted by RCprince View PostFrom what I heard, one of the cooling tubes was kinked under the motor, so the motor over heated.
http://www.offshoreelectrics.com/for...&postcount=185
I believe the problem has to do with the motor water jacket. It was much easier to blow throught the lines once the motor was removed from the stream.
Yea, one of the problems with this boat is its assembly. When you get, you have to go over ever screw and make sure its tight as well as double check all the cooling hoses to make sure they arent kinked or pinched. I was satisfied on 3S with a prop upgrade. I figure it runs as fast as the 4S setup on stock props, but for less money (that wasnt my main premise by the way). I knew I would be trying 5S or even 6S in the future with new electrics, so I figured just get some off the shelf batteries and not have to wait for ordered ones.
But now that my last run resulted in it dropping a flex shaft, Im out of comission for a while. I figure instead of trying to get parts that may or may not exist with Venom as of right now, Im just going to convert to piano wire or maybe a 3/16" flex shaft setup. The new ESCs and 5S batteries should be here next week. I already have the motor mounts and some more cooling hardware, so I wil get to work on that as well next week. When the funds get replenished then I'll order my Neu'sThe RTR Nightmare- Electric King of Shaves
Now with 540s- 62mph
New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
I don't think over heating a motor would cause this, looks more like a defect from the manufacture..Originally posted by RCprince View PostFrom what I heard, one of the cooling tubes was kinked under the motor, so the motor over heated.
If at all possible, take pictures of your upgrade process. It will help the rest of us in the future.Originally posted by NitroVal View PostYea, one of the problems with this boat is its assembly. When you get, you have to go over ever screw and make sure its tight as well as double check all the cooling hoses to make sure they arent kinked or pinched. I was satisfied on 3S with a prop upgrade. I figure it runs as fast as the 4S setup on stock props, but for less money (that wasnt my main premise by the way). I knew I would be trying 5S or even 6S in the future with new electrics, so I figured just get some off the shelf batteries and not have to wait for ordered ones.
Of course, thanks in advance...
Restriction was the word.Originally posted by Drag Boat Bob View PostThere were no kinks in the water tubing. See my post #185:
I believe the problem has to do with the motor water jacket. It was much easier to blow throught the lines once the motor was removed from the stream.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Maybe we should pass the offering plate around and help Drag Boat Bob get some new NEU or Fiegao 380s..Originally posted by Drag Boat Bob View PostNow that I am back to a decent internet connection, I thought I'd post pics of the motor.
I can hear the coins clinking already..LOL!
In the meantime...
What do you think of replacing both motors with a couple of Ammo 28-56-3200's and run them on the 3s batteries that I have? Of course I would have to find some water jackets that fit.
At least they are in stock at Tower and I could get them in a couple of days.
http://www3.towerhobbies.com/cgi-bin...?&I=LXLWY8&P=7
The stock venom motor is approx 53mm long. It is hard to tell with the way the water jacket extends beyond the back end of the motor. It's almost 61mm including the water jacket.
I've been looking at these http://www.lightflightrc.com/HTML/pr...RC-28-58-1.htmOriginally posted by Drag Boat Bob View PostI can hear the coins clinking already..LOL!
In the meantime...
The stock venom motor is approx 53mm long. It is hard to tell with the way the water jacket extends beyond the back end of the motor. It's almost 61mm including the water jacket.Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Since these guys are not too far from me, I will look into their products.Originally posted by RCprince View PostI've been looking at these http://www.lightflightrc.com/HTML/pr...RC-28-58-1.htm
I will say that it looks good on paper...
Check Rcgroups, some guys are pulling 1500-2000watts on 6s+Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
Dave a cool dude, I've ordered from him many times, kinda reminds me of Steve.Originally posted by Drag Boat Bob View PostSince these guys are not too far from me, I will look into their products.
I will say that it looks good on paper...Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
My two cents on vemon group I had a bad 5400 3s lipo I bought from a local hobby shop .I had to return it to vemon . It took 4 months and I can not count
how maney phone calls . I finley emailed my dipleasure to them. and I finley got a new battery, but it was not the same it was a5000 3s but they said it was the same with a differnt lable. I wont buy from them agine
Bob Big
