EKOS replacing the outrunners????
  • Skullcracken
    • 728
    Hi guys. I have a new EKOS with the outrunners and they can only handle 3s. What motors are some of you guys using on the newer EKOS to replace the outrunners?
  • Vinnie909
    • May 2011
    • 45
    good post i would also like to know what motor to put in it, and also do i use the stock motor mounts or change them out?!
    • Skullcracken
      • 728
      I actually tried them out and they seem to work fine. I was worried the length and weight would be a problem with the Feigao's but the mount seems to hold them fine. Bench revving them they didn't seem to move or vibrate. This is also a considerably easier mount to use. One vertical screw rather than trying to reach into the sponson and turn rear facing screws, which was unbelievable frustrating.
      • Vinnie909
        • May 2011
        • 45
        k cool, so u put the feigao's 540xl on the stock out runners mounts? did u have to get drifferent couplers to go to the motor shaft?
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          What's the diameter on the inside of the mounts? Or outside of the motor? I may be able to get some outrunners rated much higher.
          • Vinnie909
            • May 2011
            • 45
            this is what the specs say for the stock outrunners on venoms web site, but no info on the mounts
            Specs
            Length: 41mm
            Diameter: 27.8mm
            Weight: 80g
            Battery: 2-5 Lipos
            Max Current: 42A
            Kv: 2700
            No Load Current: 2.1A
            hopefuly that helps, if u find some better outrunners or inrunners that will fit the stock mounts let me know ill buy some, right now i took my boat out with me to lake havasu, AZ and was running 4s lipos and it did great the stock ESC didnt even get hot!! but the outrunners were hot but were still running good, i just wanna find a better motor so i dont half to stress about blowing the stock ones up
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              Specs
              Length: 41mm
              Diameter: 27.8mm
              Weight: 80g
              Battery: 2-5 Lipos
              Max Current: 42A
              Kv: 2700
              Yeah, I understand. Don't worry too much about the outrunners temps. They can get hot and still be OK. Outrunners are much more durable than inrunners. The magnets spin around the coils, so less to worry about them flying apart from the epoxy failing like the inrunners did.
              I need the actual size of the mount to help. Also the motor shaft size. There's a couple options, but not sure about those two dimensions.
              • Skullcracken
                • 728
                No. No. Im talking about the feigoa 380xl's that everyone put in the older EKOS mounts. I have two 380 9xl 2612kv. The motor mounts are for 38mm cans.
                • Skullcracken
                  • 728
                  Specs
                  Length: 41mm
                  Diameter: 27.8mm
                  Weight: 80g
                  Battery: 2-5 Lipos
                  Max Current: 42A
                  Kv: 2700
                  Feigao 380 9xl's 2612kv. Same diameter as the stock outrunners. These ran faster than the outrunners despite being lower kv, much more acceleration too.
                  • Skullcracken
                    • 728
                    How hot is ok on those outrunners. I ran mine 4s, but they were literally like a frying pan. Don't seem to handle the 4s lipos. I didn't even run long, a few passes.
                    • LarrysDrifter
                      Big Booty Daddy
                      • 3416
                      You need to measure the motor bolt spacing, then you'll know what you can use. 380 motors have 19mm spacing, and 540's have 25mm spacing. The old EKOS mounts have a 19mm spacing. I run 540's with the old mounts. I run Arc motors with dual bolt pattern spacing. And these motors run awesome by the way. Here's a link to them.
                      They are a bit pricey, but you definitely get what you pay for. Only a Neu of the same size MIGHT out perform them. Bad part is, they don't make a 40mm can. If they did, some other manufacturers feathers would be ruffled.
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        That's the high rpm and load creating the extra heat. Use the smaller props on 4s and you'll do better and might even go faster. The 36mm props are for 3s. Their 32mm props worked well on 4s for me @2700kv.
                        • Skullcracken
                          • 728
                          Thanks for the feedback but the new mounts are around the can. They don't have bolt mounts for the end of the motors like Venoms old green motors. The Feigao's fit, and perform better than the outrunners that are stock on the newer EKOS. The 540 size is definitely out. Limited to 380's or replace the mounts.
                          • LarrysDrifter
                            Big Booty Daddy
                            • 3416
                            Correct me if I'm wrong, but if you are able to install 380 motors in your mounts, Arc makes 380's in various kv's. They have a 2800kv that would scream and run cooler than any fegiao 2 pole. Very efficient motors. Use 120 amp speedos with x442's and you'll be sittin pretty.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Still need to know the inside measurement on the new style mounts. That'll tell us what motors will fit. =)
                              Larry's got the good setup info on these 32" twin cats, so as soon as we know what size motors will fit, Larry knows how a bunch of them perform and how to power them.
