prop suggestions
  • DyrtyByrd
    • May 2010
    • 163
    prop suggestions
    i just got an ekos looking for a good prop to start out with on my maiden i would like to use one that i already have this is the setup
    leopard 4082 1500kv
    seaking 180amp
    .187 flex
    two 3s 4000 mah 40c in paralell (6s)
    hoping to get close to 60mph but would like to start conservativly and go from there here are the props i have
    k 42 plastic, 4 for pitch?
    1.4x45 plastic it also says b-2 on the hub
    grim racer 40x53
    im not hip on all the different prop designations i got these from a purchase but anyways any help is apprieciated thanks
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3416
    I would start with an X445.
    • JPriami
      N4FOX
      • 1711
      if you just want to test and buy a cheap prop you dont need to sharpen look at the CF props sold here on OSE. They have a CF 45mm prop comparable to the 445 series. then if you like it and want the metal version buy the x445 and have it done or do it yourself, sharpen and balance the prop.
      im betting a x645 or m645 would drive that boat near 60 on 6S
      • DyrtyByrd
        • May 2010
        • 163
        i tried a 1.4x45 today and shredded the prop it was porposing and wah-ing real bad and then it broke so i put my k42 back on it it runs fast and ultra smooth i dont know how fast im shooting for 60 but would estimate mid 50s maybe, waiting on my gps and then ill know for sure
        • JPriami
          N4FOX
          • 1711
          Did you leave any gap in the flex cable to allow for swelling? Thats odd behavior.
          • DyrtyByrd
            • May 2010
            • 163
            i dont know i just seen a vid of a miss geico using a 2030kv on 4s2p turning a 445 , my boats bigger, i dont know why it wouldnt take the 445
            jpriami if your asking if there is a gap between the drive dog and the strut then no but my flex came with what looks/feels like a blackish gray plastic washer that goes between the strut and dog so i assumed that it shoud be butted up to the strut if im wrong please let me know i really want this thing to settle down and scoot like it should also im not sure if the 1.4x45 i used was carbon or not any ways heres my setup any help is appreiciated
            leo 4082 1500kv
            t180
            .187 flex
            6s2p
            im turning 33300 unloaded rpms
            • GP73
              • 546
              You need to leave a gap between the drive dog and the plastic washer, at least 1/8" or even more.
              leo 4082 1500kv
              t180
              .187 flex
              6s2p
              • JPriami
                N4FOX
                • 1711
                I agree you need to leave a gap. The cable shrinks a little under a load.
                • DyrtyByrd
                  • May 2010
                  • 163
                  so leave a gap, then is it ok if the washer is just flopping around there? are you even supposed to have a washer there? im still not sure why my prop broke
                  • JPriami
                    N4FOX
                    • 1711
                    The washer should be Teflon. Sometimes they are thin fiber. It's called a thrust washer normally. It has other names too. If the gap in the cable isn't enough it's supposed to keep metal to metal contact from occurring. Sound like you hit something somehow if the prop actually broke.
                    • martin
                      • 2881
                      With the power & speed that motor is capable of you should really be useing metal props, You may get away with carbon props but certainly not plastic. Thanks.
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        i dont know i just seen a vid of a miss geico using a 2030kv on 4s2p turning a 445 , my boats bigger, i dont know why it wouldnt take the 445jpriami if your asking if there is a gap between the drive dog and the strut then no but my flex came with what looks/feels like a blackish gray plastic washer that goes between the strut and dog so i assumed that it shoud be butted up to the strut if im wrong please let me know i really want this thing to settle down and scoot like it should also im not sure if the 1.4x45 i used was carbon or not any ways heres my setup any help is appreiciated
                        leo 4082 1500kv
                        t180
                        .187 flex
                        6s2p
                        The venom is only approx 3" longer then the MG. Yes you could swing a MUCH bigger prop then the 2030 motor on the MG in the video you seen, BUT the hull may not like the bigger prop. With the the amount of torque your motor can put out and with a larger prop, you may experience a lot of torque roll. You still need a gap between the strut and drive dog. Gap should be the diameter of the cable. I also think x445 or m445 would work nicely. A x645, prather 220 are some other props to try as well. You maybe able to get away with a x447 2 blade.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • DyrtyByrd
                          • May 2010
                          • 163
                          see thats what i was thinking from what ive been told that a 445 should work and may push me past 60mph but the 445 looks huge on the ekos i have a different rudder setup and the 445 is about 4mm from the rudder boom, as soon as i put it on i got way more torque roll alot of wah some kid of gyrating motion and it almost blew over and i never even took it to full throttle but even at 1/2 to 3/4 throttle it was faster than the 442 i know its asking alot but do you think the bad habbits can be tuned out and if so where would i start, thanks
                          • JPriami
                            N4FOX
                            • 1711
                            Try a Octura 440 3 blade prop if your uncomfortable with how close the 45mm blades come to the rudder boom. You should get some decent speed with that and save space.
                            Or if you really want to make it go try a ABC 1616-10-50(3) CLL
                            thats another prop about the same size as the Octura 440 3 but has a 1.6 pitch vs the Octura 1.4
                            But you may run into cavitation problems with a smaller prop and more pitch at dead stop to low speeds if u gun it suddenly.
                            You should experience less torque roll with these smaller props. But I think if you were running the flex with no gap prior you could possibly experience torque roll because the cable was binding making the motor work harder. So that could be a partial contributing factor to that problem.
                            Also look at the strut it might be able to move down a little if needed?
                            • DyrtyByrd
                              • May 2010
                              • 163
                              thanks guys i got a 445 carbon on the way and will try it again also just got my gps today so tomorow i will get some speed tests on the 442
