EKOS clone and upgrade questions.
  • JPriami
    N4FOX
    • 1711
    #256
    well its too hot then on the motor shaft. guess I will have to re think some things. Why would higher amp esc's make it (the motor) run cooler?
    I'll just take the advice for now and order the Turnigy 180's
    • forescott
      Hopelessly Addicted to RC
      • 3009
      #257
      Higher amp esc's wont help with motor cooling. you're just running a hot setup with the 40mm props. Just need to keep your run-times short. One thing that may help a bit is to decrease the motor timing!
      • JPriami
        N4FOX
        • 1711
        #258
        My motor timing is set at the lowest setting I think. Because my esc's are different than the venom ones. I'll check them tonight.
        • Bug777
          • Jun 2010
          • 103
          #259
          I have heard that if the timing is too low then this will increase the heat as well so perhaps you may need to increse the timing a little to decrease your temps.
          • JPriami
            N4FOX
            • 1711
            #260
            Thanks. right now i took my boat apart and dont know when i will be running it again. lifes getting hectic here
            • JPriami
              N4FOX
              • 1711
              #261
              Got some time to put her back together last week. Nothing new yet tho. trying to get my hands on another boat to add to my RC collection
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3416
                #262
                Wow.Your back.Was wondering if you would make it back to boatland.
                • JPriami
                  N4FOX
                  • 1711
                  #263
                  Yeah. Been busy in life. I have a traxxas spartan on back order. I havent messed with those 2 180 amp esc's yet. They are in the boxes. Prob won't unless I have to lol. Think I'd like to find some different motors to try on the cat project tho. Did you get urs back together?
                  • JPriami
                    N4FOX
                    • 1711
                    #264
                    Just got notice from tower. They have venom ekos's in stock
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3416
                      #265
                      I got it back together,then wiped it out again.Decided to retire the wore out hull and bought a hull from FighterCat.Its the silver one in my avatar using the hardware from my EKOS.Now it has 2 Arc 36 x55 2800kv motors on 4s.Heres a link to different motors for your twin.
                      • JPriami
                        N4FOX
                        • 1711
                        #266
                        whoohooo dogggyy.. i swear prices of stuff keep going up up up up but my wages dont match the cost of stuff lol.
                        thanks for the link.
                        How did she run? any new vids?
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3416
                          #267
                          It ran ok.Water was choppy on the maiden run.Theres a video in my build thread of the 1st run.Dont know how to link it,but its called,Larrys 32" Twin Cat,I think.
                          • richt
                            • Dec 2010
                            • 67
                            #268
                            hi this richard i have a kos hull i want to see what the best sit upi for it .i will like to get 60 or better mph can you let me know.what is the best motor . thanks
                            • JPriami
                              N4FOX
                              • 1711
                              #269
                              Welcome to the forum. Get a good set of 14.8v lipos, A pair of feigao 380 9xl motors and the aluminum jackets, a pair of Turnigy or seaking 120 amp esc's. and some larger 2 blade props like the CF 40mm ones mentioned in this post and you will hit 60mph. There is some other stuff you will want to do, but what i mentioned will get you 60 mph. read though this whole section about these hulls and what others have done to go faster and make decisions based on what you feel comfortable with.
                              • richt
                                • Dec 2010
                                • 67
                                #270
                                thanks for your help .i just have the hull what is the best stinger i have some sv27
