EKOS clone and upgrade questions.
  • JPriami
    N4FOX
    • 1711
    I ordered a Dragon Saga cat from the UK this week. I did a bunch of looking around to find the specs of everything and now I might be heading for trouble. because I was originally going to buy the new EKOS with the new outrunners. at that time I ordered new lipos for the boat and 36mm machine props by venom. But I ended up getting this other boat thats a clone of it because I liked the paint better because its not the EKOS paint job like everyone else has. So I want to know whats best or has been proven to work best to upgrade things like the motors in the EKOS boats.
    Here is a couple pics of the boat.
    Specs:
    Length - 820mm
    Width - 240mm
    Weight - 2400g
    Speed Controller - 2x 70 Amp Water Cooled (Included)
    Servos - 1 (Included)
    Motor - 2x Water Cooled 2636kv brushless (Included)
    Battery - 2x 11.1v 2100 - 4500Mah Lipo (Not Included)
    Hull Material - Fibreglass (FRP). Propeller - D36 x P1.4
    The ESC's are 70 amp
    Specs:
    Type - Water Cooled
    Voltage - 7.4 - 22.2v (2 - 6 cells lipo)
    BEC - 5.5v @ 4 amp
    Battery Connector - T-Style
    The motors are Feisuda 380 2848-2636Kv
    Specs:
    15 Turn
    27 Amp
    0.0341 Resistance
    2636 Kv
    0.9 I0(A)
    When I ordered my lipos I was thinking I would be gettin gthe EKOS. I ordered Hyperion EX 3S 5000mAh 45C packs
    Now after finding the motor specs, well I'm worried I will smoke those motors running my packs. Because they are only rated for 27 amps. Am I right to figure that’s a problem? I am not buying smaller lipo packs lol. But I will try to buy better motors. What would be the best replacement motors that will drop in without too much modding and give me much more speed and even turn a bigger prop if I have to. I am thinking I maybe buying new esc's at some point if i kill these. wont know till I cross that brigde.
  • JPriami
    N4FOX
    • 1711
    I see these motors are a good upgrade. Are they a drop in replacement or a little work needed? If so what all is needed to complete? And can you turn a larger prop with these?
    But 9xl or 10xl better for 3-4S lipos? because I may try to get 4S if I cant get this thing to break 50mph on 3S
    Where are you guys getting the wire drives from? I seen them one night in a search but didnt save it on this pc.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3416
      Read the SeaKing 120esc thread and others.There will be all the info you can ever need on upgrading these hulls.And 9xl's and 10xl's are good motors that bolt right in.Youll be spending alot of money on this to get good speed out of it.Wire drives and other drive hardware is from rcraceboats.com.click on the EKOS part and youll be there.Be sure you read up on things before you buy.
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3416
        One more thing-66 mph is the top mile per hour that needs to be broken here with that hull.Good luck.
        • Rumdog
          • 6667
          the main thing you'll need to do is make sure that the props are counter rotating. Spinning toward each other. In the pics, they are not counter rotating. Yhis will require a right hand flex and clockwise spinning prop, or wire drives.
          • JPriami
            N4FOX
            • 1711
            Thanks. I will inspect the flex cables when get it. I have a pair of counter rotating 36 mm props for it that came the other day
            • JPriami
              N4FOX
              • 1711
              from that pic of the boat props it looks like i will need a right hand flex cable to use my counter rotation props right? I just want a 2nd opnion before i order
              • Rumdog
                • 6667
                Yep, if it comes like in the pics, you'll need a right hand flex.
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3416
                  Or use wire drives.I have them in my EKOS,works good.
                  • JPriami
                    N4FOX
                    • 1711
                    Im going to try and get the wire drives. I just need to sell some of the stuff I dont use to reinvest in this area of the hobby lol. this keeps me out of trouble with the ole lady
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3416
                      You ainta kiddin there.I have about $600 in my EKOS upgrading everything.But now its fast and fun.Untill I wreked bad Monday.Went 66mph and got air.You can get wires from rcraceboat.som.They go right in.Should be the same for your boat as the EKOS.
                      • JPriami
                        N4FOX
                        • 1711
                        awe man sorry about the accident. 66mph thats sweet for this boat
                        did you find the best props for your setup yet or did you have time to play around with diffrent props?
                        • LarrysDrifter
                          Big Booty Daddy
                          • May 2010
                          • 3416
                          I ran 442's on it for the speed runs.Temps were 117 degrees on motors and speedos.The best props I ran were 38mm from Kintec.They can be found on the EKOS upgrades section.Dont over speed this hull.IMO,dont go faster than 50-55mph.Mine with the 38's was at 56mph.Make sure you slow down to turn.I just tore my hull down.It is gone.I found a lot of cracks that go all the way through the hull.On top of the major break.Just be careful when running top speed with your china hull.They are cool and look nice,but are thin and flimsy.Look around on the Venom King of Shaves threads-you will find a lot of info as far as upgrades for yours.I dont know for a fact,but Im pretty sure you have the same hull,just painted different.Good luck with yours and post pics and tell us what your doing with it.Ill be on the search for a new hull.
                          • JPriami
                            N4FOX
                            • 1711
                            Thanks for all your input and advice. I'll keep things updated here as I go along. right now im waiting on the boat its coming from the UK it shipped out today. In the mean time im researching the upgrade options and making my list. My lipos came today so thats was nice to get.
                            • scubasteve95
                              • Apr 2010
                              • 245
                              [QUOTE=JPriami;217126]I ordered a Dragon Saga cat from the UK this week. I did a bunch of looking around to find the specs of everything and now I might be heading for trouble. because I was originally going to buy the new EKOS with the new outrunners. at that time I ordered new lipos for the boat and 36mm machine props by venom. But I ended up getting this other boat thats a clone of it because I liked the paint better because its not the EKOS paint job like everyone else has. So I want to know whats best or has been proven to work best to upgrade things like the motors in the EKOS boats.
                              Specs:
                              Length - 820mm
                              Width - 240mm
                              Weight - 2400g
                              Specs:
                              Type - Water Cooled
                              BEC - 5.5v @ 4 amp
                              Specs:
                              15 Turn
                              27 Amp
                              0.0341 Resistance
                              2636 Kv
                              0.9 I0(A)
                              these packs will work just fine....keep it stock and run her.
                              3s-4500 or 3s 5000mah no real diff.
                              motors are less kv then the ekos...thats good
                              nice paint....makes me want to sand and paint my ekos
