SeaKing 120 esc
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3416
    SeaKing 120 esc
    I got my EKOS running again with 2 SeaKing 120 speedos.I ran it just a bit ago for about 5 minutes with no problems at all.None.Not even heat issues.After I pulled it out to check temps and put it back in,it ran fine for about 1 minute.Then,it stops,then goes about 1mph in a circle in the middle of the lake.So, I began walking to my truck to get my pole with the tennis ball while I was pulling on the throttle trigger off and on,then it takes off and I have control.When I got it in,nothing was abnormal.Plugged it in and it ran great.Anyone ever hear of this?The speedos are only about a week and half old.
  • forescott
    Hopelessly Addicted to RC
    • 3009
    Could be your receiver acting up. Did it get wet? Double check all your esc settings too.
    • forescott
      • 3009
      I have the turnigy 120's in my ekos,(same as seaking) and they have been flawless so far.
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3416
        Just a hair wet once.But its been wet before with the stuffing tubes leaking.Nothing has been soaked though.I set it in the garage with a fan blowing on it since last nite.Should be ok.And I bought the speedos that came with the programming card too.They have 10 or 12 tuning options on them but they will only let me do 4.At least I can set the low voltage cut off.Thanks for your suggestions earlier.It really hauls a@@ now with the 9xl's.Got it to 50.1 so far on 4s with the 36mm props.Hopefully I can tune the stingers and get a bit more speed out of it.I also got the Octura collets and wire drives from Jeff too.Such a better setup from stock.
        • forescott
          • 3009
          I am using ALL of the exact parts that you have on your ekos, except the turnigy esc's. You can run the cf-40 props and get just over 55mph. Truly impressive!
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3416
            Ive been checking on here for the cf-40s but theyre not in stock.Added a watch for them.Cant find them anywhere else.Guess Ill just stick to my 36's for now.One prob I do have is that my 4mm bullet nuts feel loose on my prop shafts.I put a lot of locktite on them but they just dont feel right.Afraid to lose them and my props.Just gonna have to run lock nuts I guess.It does look sweet with the bullets though.I also put in 2 of the dual water pickups like you in the bottom of the hull.Works great and looks a ton better.
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3416
              Hey forescott,which cf 40's do you use,the 4mm or 3/16?
              • forescott
                • 3009
                I used the 3/16 with the brass prop adapters.
                • forescott
                  • 3009
                  The 4mm props are threaded and dont use a prop nut, or have the notch for the drive dog. If you're careful, you could probably mod them to work with a dremmel tool if you dont want to wait.
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3416
                    Ill just wait it out.Its blowing over on the 32mm props as it is.Its not going but 47mph but I blew it over twice this morning.And there was a very slight breeze.
                    • forescott
                      • 3009
                      I have not yet had a blowover in the ekos. I wont run if its windy though. You might want to give the stingers a little negative adjustment. Remember when you change prop sizes you also need to adjust the stingers to compensate for the diameter change of the prop. The cf-40 will need more posotive trim than the 32mm 3-blades.
                      • scubasteve95
                        • Apr 2010
                        • 245
                        go to this web site he has all you need www.rcworldwide.com(i got 4 cf-40 & 4 cf-40L)
                        ose has nice pics of items you want but thats about all(out of stock)
                        i have a web site for just about every item on here...the only
                        differance there (in stock)
                        and www.kintecracing.com for the adapters
                        all items were cheaper and shipped fast
                        • forescott
                          • 3009
                          Good to know steve. I always give ose the first shot, but sometimes I just can't wait!
                          • LarrysDrifter
                            Big Booty Daddy
                            • May 2010
                            • 3416
                            Went to rcworldwide.com-those props where 30 or 35 dollars each!A bit much,but if OSE doesnt get any in soon,I might have to swing it then.Also,Kintec has metal props sharpened and balanced in 37mm and 38mm two blades for a 4mm shaft.Just got my 38's and gonna try them later today.My buddy has an Apparation boat with a 540 1500 something kv motor on 6s, and Im only about 2 to 3 boats behind him when drag racing.MY EKOS has 380 9xl's on 4s with 36mm props.Sweet.
                            • forescott
                              • 3009
                              If you can get ahold of those cf-40's, you will smoke your friend. The 40mm 2-blades make a big difference!
