Motors
  • toledo
    • 11
    Motors
    Recently, someone posted that xls' tend
    to crack in rough water due to motor bend.
    How about using 380 l instead. Are they stronger
    than oem and not break?
  • vasy
    • Dec 2009
    • 333
    not motor bend but rather front end bell pop out. This can be easily solved with a motor support at the back of the motor. 380L will have less torque compare to X Lbut will probably have less of an issue with bouncing as it is lighter. I'd still put one in even on the L if for nothing else but insurance, no reason not to have it. I see a lot of other boats use support for the back of the motors as stock.
    • VIKOS
      • Jan 2010
      • 204
      The stockys don't have back support....I'd pivot the motors down more on the motor mounts...as you can see the holes are actually oval not circles so fine tuning the way the motor sits is achievable. I keep mine as low as possible.
      • vasy
        • Dec 2009
        • 333
        True, but they are smaller. It could also be to the design of the motor. I think if the front end bell of the Feigao was threaded like many others it would hold better, but it is not and possible that some are crimped better than others so one Feigao motor will last better compare to another. The condition of the water would also play a huge factor as only in a rough water is where you would have this issue.
        • VIKOS
          • Jan 2010
          • 204
          Well I run in rough water with stockys no problem. Or at least rougher than a still pond conditions with no problems. Guess I'll see when I get them I guess
