VENOM EKOS 4S 5000mah LIKE BUTTER
  • scubasteve95
    • Apr 2010
    • 245
    #61
    Originally posted by pmisuinas View Post
    Well, I got mine in the water on 4s and it really moves. A couple of observations and some advice needed: I was surprised how low it sat in the water (4s 5000 packs) the back end was submerged to the hatch line--but it came out of the water when I hit the throttle, that's for sure.
    But it also bounced a lot--the front end was like it was on a trampoline. I take it this is a balance problem--do I need to try and push the packs forward a bit? Where are you guys balancing this hull? Have not changed any drive angles, just ran it the way it came (although I am running 9xl and cf40 props with Turnigy 120s--don't want to give any false impressions here). Thanks...Pete M
    PS--serious difference in speed between 3s and 4s packs--I use the programming box to reset the cutoff voltage when I want to just "cruise" around on 3s packs--nice to have that easy to do option...
    PPS--also, adapters for the 3/16" prop--turned out I couldn't find any brass tubing to fit without a long drive to hobby shop, so I used the outer sheath fromn a Nyrod--if you want to get fancy, make a spiral cut in the plastic, then you can slip it over the shaft and the prop fits great. but if you get tired of it breaking on you while trying a spiral cut, a straight cut will work just as well.
    i'm running the same size packs and mine doesn't sit that low,
    can you give me some measurements (were do the packs sit in the hull)
    maybe the battery holder is to far aft?
    • VIKOS
      • Jan 2010
      • 204
      #62
      Ordering wire drives,120 esc and 9xl,and 10xl either or as spares..think both motors will run on 4s or 5s. Gona be real fun soon
      • pmisuinas
        • Mar 2008
        • 173
        #63
        The packs sit against the back of the battery box, I had to remove the ply front of the box so they would fit, as they exceeded the size of the box. The packs together weigh 37oz. The ESCs fit under the hull top, in front of the packs. I can maybe move then a bit forward, certainly can't hurt--help both the low sitting rear and the porposing, I would think...
        • pmisuinas
          • Mar 2008
          • 173
          #64
          I got this from another KOS thread:
          I don' t like how heavy and low my other EKOS is with less weight than this as the water line often covers the rear of the hatch when sitting still.
          Apparently I'm not the only one that has a boat that sits low in the water
          • forescott
            Hopelessly Addicted to RC
            • 3009
            #65
            They all sit pretty low in the water, but the water line shouldnt be high enough to seep into the hatch.
            • scubasteve95
              • Apr 2010
              • 245
              #66
              the hull sitting to low in the water?
              mine sits right at the edge of the transom right were the black
              section starts...3 inches from the hatch
              so something is to far aft.
              how far back from the transom does your
              battery holder sit?
              mine is 7"15/16 to the transom were the rudder mounts
              from the rear of the battery holder.cant hurt to check it.
              and can you give me the measurements of your packs,
              dont know why you would of had to remove the front of holder.
              like i said i run the same 4s 5000mah pack and i had to put a piece of
              the foam i took off the hatch in my holder to keep them from moving.
              • forescott
                • 3009
                #67
                I run 3300 4s packs to keep the wight down and increase speed! Plenty enough run time for me. Especially with a hot setup!
                • scubasteve95
                  • Apr 2010
                  • 245
                  #68
                  how long?
                  and hot is a understatement for that rig!!!!!!!!
                  • forescott
                    • 3009
                    #69
                    It does'nt really run too hot. If I tried to run it for 15 minutes it would! I usually run it for about 6-8 minutes without hitting the lvc.
                    • scubasteve95
                      • Apr 2010
                      • 245
                      #70
                      NO NO NO!!!!!!!!!!
                      you misunderstand............
                      i ment hot was not a strong enough word for your set-up.
                      DIALED IN,SUPER SMOKEN KICK A$$,or maybe even SEXY SWEET
                      ............(still talken about your set-up...i meen your boat)
                      and 6-8 is great at that speed....................................57mph
                      you stink.....i'm @49mph and i was hummen
                      • forescott
                        • 3009
                        #71
                        NO NO NO!!!!!!!!!!
                        aaaaah, o.k. @ 57mph I'm pretty much biting my fingernails. Its plenty fast enough for me, and I wouldnt want to try and push it anymore. I have a nice set of octura 442's that I could run and probably get 60, but It would have to be just a quick saw run. The motors would get hot really fast I'm sure.
                        • scubasteve95
                          • Apr 2010
                          • 245
                          #72
                          NICE...........
                          WANT TO SELL THE X442's?
                          need a set and don't want to wait for my guy to bal & sharpen....
                          • forescott
                            • 3009
                            #73
                            NICE...........
                            I'm gonna hold on to em for a bit. I had egneg sharpen/balance/polish/de-toungue them for me and they cost me about 90-bucks for the pair after all said and done.
                            • scubasteve95
                              • Apr 2010
                              • 245
                              #74
                              from what i have heard,if he did them i'll give you a $100.00
                              • forescott
                                • 3009
                                #75
                                You're really tempting me, but I have to decline. I may end up using them with the 10xl's later so I think I'll hold on to them for now. Thanks for the generous offer though.
