New EKOS C1 Pre-Use Checklist
  • scubasteve95
    • Apr 2010
    • 245
    the pcb stops all failures...at least thats what they tell me and so far it works perfect.
    • scubasteve95
      • Apr 2010
      • 245
      the packs get to about 120 degrees and start to shut down, the good news is thats about all the pack has left in it, cells are @ about 3.40v across the board.
      • Rumdog
        • 6667
        That is impossible.If my motor is pulling 120 amps continuous and the packs are 20c 5000 mah, they are only capable of 100 amps of continuous power, They WILL get hot, voltage will drop below lvc settings of the esc and that equals problems. How can a pcb on a battery stop my motor from pulling amps? How can it STOP heat?
        • Rumdog
          • 6667
          The system shuts down because the lvc in the esc is kicking in. How can a pack "start" to shut down?
            • 9481
            • scubasteve95
              • Apr 2010
              • 245
              a pcb can do what ever it is designed to do.
              if you are pulling 120 amps you should not be using a 20c 5000 pack to start with.
              once battery gets to any of the cut off points it shuts down...its that simple.
              just like a pcb in a lvc stops voltage from geting to low.
                • 9481
                Originally posted by forescott View Post
                I've got 2-more
                * As with any F.E. boat, stop and check your temps after a few minutes run-time. If any one or more components are too hot, stop immediately. Dont burn a hole in your hull!!
                * Dont make any attempts to run 4s packs with the factory electronics. No matter what the venom videos show, or what venom claims. And if your motors still work after a few minutes on 3s, consider yourself lucky!!
                and sell it quick!
                • scubasteve95
                  • Apr 2010
                  • 245
                  I don't know why you guys have so much anger built up,can't someone that has nothing but good with this boat share it with others?
                  • scubasteve95
                    • Apr 2010
                    • 245
                    GO TO THE VENOM 4S 5000mah LIKE BUTTER THEAD AND SEE HOW THIS 1 BOAT ACTS.
                    • Rumdog
                      • 6667
                      It's not anger, just questions. Seems you are the only one having any luck with this boat at all. Therefore we want to know your setup details and why it may be working.
                      • scubasteve95
                        • Apr 2010
                        • 245
                        No problem............ask away..............
                          • 9481
                          not good with the pickup on the bottom of the sponson like you have
                            • 9481
                            I WISH I COULD AGREE WITH ALL THIS ................BUT
                            I HAVE HAD NOTHING BUT GREAT RESULTS FROM MY EKOS AND FROM
                            VENOM TECH SUPPORT
                            I HAVE BEEN RUNNING 4S 5000mah
                            SINCE DAY 1....8mins @ WFO NO PROBLEMS TO DATE...
                            CHECK THEAD TO SEE.
                            I WOULD LIKE TO ADD 1 MORE THING TO THE FE/EKOS CHECK LIST
                            AFTER EACH AND EVERY RUN,NO EXCEPTIONS,EVEN IF YOU JUST COME IN TO CHECK HEAT...SPARY WD-40 OR
                            SOME TYPE OF WATER SHED LUBE ON STINGER BEARINGS...DONT BE SHY WITH THE LUBE EITHER LAY IT ON.
                            so you only have 8mins of run time?
                            and you should use grease on the bearings, WD does not lube like grease will
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              Isn't WD used to clean off good grease? At least that's what I use it for.
                              ________
                              Buy Vapir Vaporizer
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3784
                                BTW- I'm really glad to hear of your successes and am really looking forward to some video.
                                ________
                                Chrysler sunbeam specifications
