forescot: any need to swat the sock esc of the king of shaves for bigger ones with the 9xl motor?
Feigao motor install pics
They will work o.k. but the xl motors can handle larger props like the 36mm venoms easily. Maybe even larger. If you want to be safe stick with the 36mm 3-blades.Originally posted by henrik.backe.hansen View Postany thoughts on whether the 32mm venom props will be too small with the feigao 9xl on 4s?
I think the stock esc's would be ok with the 32mm props, but if you want to get the most out of the xl motors and prop-up, you'll be pulling more amps and need higher amp rated esc's.Originally posted by henrik.backe.hansen View Postforescot: any need to swat the sock esc of the king of shaves for bigger ones with the 9xl motor?
As I have one temp guage for each motor when running the boat. what kind of temp should be fine the for 9xl motor and the turnigy 120A (just ordered two of them). In other words, what is the tmep limit on the esc and motor?
I dont know, I dont have a data logger. I know the motor temps so far are in the 110 degree range, and I am using 120-amp speed controls, which should be more than adequate for motors that have a 65amp constant rating. So far so good!Originally posted by vasy View Posthow many amps did it pull on the 40mm props?
So friend and I ran his boat today on 380 10XL with 40mm 2 bladed props and got about 1000 watts max reading on 14.8v. I see OSE rates this motors as "440 Watts Maximum with proper cooling" so wonder if 1000 is too much.... now, 1000 was peak as I don't have a data logger just a watt meeter that records the top reading.
The motor seemed cool, just the shaft itself was hot, had no problems holding the back plate by had for 20 seconds and this is after 4 minute run.
I removed the stock motors last night ...waiting for my Feigao 9XLs to arrive.
Question please guys: Just noticed that the wires on the back of stock motors are same color and from what I see (or not see).
How they heck do you know which ones are which when plugging the wires from new motors back into the ESCs??
Thanks!
It doesn't matter. Just plug all 3 wires to the esc then check which direction the motor is spinning. If it spins counter-clockwise your good, if it spins clockwise change any two of the wires. That's it.Originally posted by Team Jericho View PostI removed the stock motors last night ...waiting for my Feigao 9XLs to arrive.
Thanks!
I too will be going with the 9xl or the 10xl as soon as the motors give out..think I don't understand is these motors should be sealed and have its own lubrication..is it just bad wiring used that makes the stockys crap...as soon as rcraceboat gets these motors gona put another order in..still trying to figure out which is a better motor the 9xl or the 10xl both fit in the stock motor mounts..which is pretty cool..might order some ESC's also but run the stock ESC's till they burn up..everything seems cool even with the aluminum 36mm props just hoping this coupler and flex shafts are way better than stockys.
Another feigao motor install tip. The ose coolers touch the battery trays. You might need to dremmel out a small notch.Attached Files
As far as I know looking at the props from the rear. The left prop should turn clockwise and the right prop counterclockwise not both props counterclockwise. Ned to inform people that your reverseing polarity if you do it that way.Originally posted by Diesel6401 View PostIt doesn't matter. Just plug all 3 wires to the esc then check which direction the motor is spinning. If it spins counter-clockwise your good, if it spins clockwise change any two of the wires. That's it.
The focus of my post was that switching any 2 of the 3 wires between the motor and esc will change direction. A single motor boat spins ccw, which was y i added that point, but for dual motors obviously its different.Originally posted by VIKOS View PostAs far as I know looking at the props from the rear. The left prop should turn clockwise and the right prop counterclockwise not both props counterclockwise. Ned to inform people that your reverseing polarity if you do it that way.
