Flex Shaft Saver
  • Jeff Wohlt
    • 2716
    I was told by Venom that most cables lost are due to coming out of the coupler and not tightening the set screws good. Always use locktite on those.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • VIKOS
      • Jan 2010
      • 204
      Well it seems the set screws are crap I use a 1 Allen hex and it's basically stripped. Best advice is to use a star key of the same size. More points for it to grap too really.
      • bill1473
        • Jan 2010
        • 46
        R u tAlking about the collers cause the same *!***!***!***!** happed to me.
        • Jeff Wohlt
          • 2716
          Well maybe some couplers are in order as well. The smallest I use is 6/32.
          I already have the specs on them and would be easy to make a better version
          www.rcraceboat.com
          • LarrysDrifter
            Big Booty Daddy
            • 3278
            Originally posted by VIKOS View Post
            Got my shafts and cast props yesterday..stayed up till 3 in the morning set up greasing and adjusting trim..boat ran great today awesome..sure I was a lil scared to open her up alot in fear of losing another shaft and or prop..might go back to the plastic props just so if I do I won't be spending another 30 bucks for props...anyways my question is this you have to actually cut the flex shaft to fit..now how do you get the metal wounds not to unwrap themselfs or not so much unwrap but become loose and cause restriction from going into shaft housing and into the motor coupler..any remedies would be great..every time I install it it acts as if its been blocked off by something and the slightly unwrapped wounds actually cause it. ohhhh lol installed the props backwards and was trying to figure out why she kept going in reverse..so I switchs sides and she ran forward lol kinda funny..
            You have to solder the ends of cables after you cut them or they will unravel.If thats what you mean by the metal wounds to not unwrap themselves.Rcraceboats.com sells some parts for the ekos.shafts too.Im thinking of running wire drives and octura couplers.No more set screws to worry about.Venom does not use locktite on anything.You have to do it yourself before the 1st trip out.Lost one of mine cause I didnt check anything.
              • 9438
              Vikos, You have to be shure you have the right flex cable in the correct side or else the cables could unwind regardless of Solder or set screws.
              The wire twist in the cables is opposite and if installed wrong it is not going to be good sooner than later. Just a caution, hopefully you have it right.
              • Jeff Wohlt
                • 2716
                Someone told me the Octura Hex is hard to tighten in that area. I think they work great but you have to be able to get them tight.
                The wiredrives are working great form the input I have gotten back from customers.
                I am also now soldering the ends and they come with new stuffing tubes that fit perfectly.
                www.rcraceboat.com
                  • 9438
                  You have me thinking now Jeff. I better check I can do flex hex's. I still have some wire drive kicking about, maybe some couplers. LYK.
                  • Jeff Wohlt
                    • 2716
                    I would think you could get some wrenches in there and get them tight.
                    www.rcraceboat.com
                    • Jeff Wohlt
                      • 2716
                      I also had a couple people put the wrong cable in the wrong side because I did not mark them. There is an easy way to see which is left and right.
                      www.rcraceboat.com
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3278
                        Have I told anyone how much I hate Venom products?The ekos hull is nice, but the innards arent worth a hoot.Why would anyone buy a boat only to literally HAVE to put aftermarket parts in it to make it a dependable boat?I definitely learned the hard way from my mistake.
