Gas or electric KOS?
  • BHChieftain
    Fast Electric Addict
    • 1964
    I really like this catamaran, but I'm torn between the gas and electric versions... any recommendations?
    -Chief
  • Doug Smock
    • 5264
    -Chief
    I haven't seen the FE version run so I have no comment on it.
    I have seen the gas KOS and I wasn't impressed with it's speed or handling. If you are just looking for something to play around with, you may be happy with it. If your looking for performance, this is probably not the boat for you.
    Just my opinion,
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • NitroVal
      • Jun 2009
      • 423
      The gas KOS is pretty expensive, and from what I have heard its pretty slow unless you get the 4.5KWA motor or something else bigger and better than the stocker, which is another $300-$500. For half the price, you could get the EKOS and put some nice running gear in it and run 40-50mph..
      The RTR Nightmare- Electric King of Shaves
      Now with 540s- 62mph
      New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
      • Ub Hauled
        • 3031
        if you like a $999 tug boat that looks like a Cat then go for the Gas version... if you like a potentially really fast boat, go with the FE.
        Don't get me wrong, there is work to be done on the FE one but it's a cheaper starting point and with little money you can get her running fast and pretty consistent.
        • BHChieftain
          • 1964
          Thanks for the tips. For the fellow EKOS owners out there, what upgrades do you recommend?
          -Chief
          • NitroVal
            • Jun 2009
            • 423
            Definitely motors.. The stock ones have been showing alot of problems over 3S or with aftermarket props. Im sure they will do fine one 3S with stock props, but you'll be lucky to get 35mph out of it. If you want to spend the money, get some Neu 11xx motors. Turnigy also makes some cheaper ones that may do better.
              • 9479
              A stock Gas KOS gets 50mph+ with prop change and good tune!
              • Ub Hauled
                • 3031
                I'd get the hull and have a one drive system... that way I could chose what I want under the hood.
                I understand that takes away from the scale look, but I like performance as well as looks, and that way I have a happy compromise.
                If you want 2 drive sys, I'd find a way to change to motors and use some decent props... even on 3s it should go
                • andym
                  More Go Than Show Prop Co
                  • 2406
                  Not from what I have seen, 38-37 tops
                    • 9479
                    Then look in a different direction!
                    they are out there
                    • andym
                      • 2406
                      Yeah? Well show us where and how !! If some one says they have a bog stock one doing 50mph with only a prop change they are full of bull. Just do the math !! A standard Zen can not put out the power for it...
                        • 9479
                        Just passing along what was told to me...
                        stock motor, prop change, and I think a different pipe
