timing for the venom motor.
  • cogwheel1
    • 50
    I have a King of Shaves 34" brushless. Has anyone played with the timing? The factory doesnt even know what the stock timing is nor what it should be! They can't even tell me the specs on the motor. Anybody know?
  • NitroVal
    • Jun 2009
    • 423
    I played with the timing in all directions and the factory default setting is the best for power/cooling to be in the safe range. I honestly wouldnt go higher in the timing due to the possibility of motor failure
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    • cogwheel1
      • 50
      I may have inadvertently changed the factory timing, and venom can't tell me what it is.. What is it? 0?
      • NitroVal
        • Jun 2009
        • 423
        IIRC, it is 7*. I'll double check when I get home tonite
        • Chris Nicastro
          • Sep 2009
          • 84
          The factory default timing is setting #4 11.25deg. advance. You can use that or setting #1 which is 0deg. but if youuse anything higher you have to watch temps and adjust accordingly.
          Chris
          VENOM RACING R&D
          • VIKOS
            • Jan 2010
            • 204
            Now what if your running say colder water such as say 45-50 degree temps shouldn't be an issue at running more advanced timing shouldn't be a problem.
            • NitroVal
              • Jun 2009
              • 423
              I wouldnt touch the timing. These motors are tempermental enough, I would just leave it stock. Advancing the timing wont get you much anyways, maybe 1-2mph.
              • skater368
                • Apr 2010
                • 349
                how do you get it back to factory timing?
                beating amsoil boat. 1 race at a time !!!
                • JonCBrand
                  • Apr 2010
                  • 17
                  I just ran my EKOS with stock motors and 3S lipo in 55F water, after 5 mins at WOT, motors and esc were just above the water temp about 62F. That was at 0 timing, so Im going to go up to the 11.25 this weekend and see how it runs.
                  • annmitchael
                    • Mar 2010
                    • 2
                    does anyone ekos form venom split on the side
                    • scubasteve95
                      • Apr 2010
                      • 245
                      Originally posted by scubasteve95 View Post
                      ITS VERY EASY
                      GO TO VENOM SITE AND CLICK ON THE PICTURE OF THE EKOS
                      THEN CLICK DOCUMENTS
                      GO TO PAGE 5 AND FOLLOW THE DIRECTIONS.
                      I SET MY TIMING TO - 0 ADDED 6 INLETS AND OUTLETS AND
                      AM HAVING NO ISSUES ON 4s,BUT,
                      (DO NOT RUN 4s ..... JUST BECAUSE IT WORKS FOR ME)
                      I'M NOT SAYING DON'T BUT IF YOU DO ITS ON YOU......
                      JUST HAVE FUN WHAT EVER YOU DO
                      I AM ALSO CHECKING TO SEE IF THE
                      Hobbywing LED Program Card For Brushless ESC Version 2
                      WILL WORK,IT WILL BE SUPER EASY IF IT DOES AT ONLY
                      $10.70 SHIPPED FROM EBAY
                      • forescott
                        Hopelessly Addicted to RC
                        • 3009
                        Your manual has a whole page on how to change the settings from the transmitter. Its not too difficult. You can download the manual from venoms website if you dont have it.
                        • scubasteve95
                          • Apr 2010
                          • 245
                          THIS IS ALL OLD NEWS..
                          IT IS EASY FROM THE TX BUT MOST OF THE ESC's I BEEN SEEING
                          WANT YOU TO USE A PROGRAMMER JUST TO BE SAFE AND
                          SEEING IT ON A SCREEN FOR ME IS MUCH BETTER,FOR
                          10 BUCKS TO KNOW I GOT IT RIGHT...I'M OK WITH THAT
                          • scubasteve95
                            • Apr 2010
                            • 245
                            hobbywing programmer works perfect on
                            ekos esc's
                            took all of 30 sec. to program esc
                            led readout and controlls A+
