Move over and make room for the new bad boy of rtr's
    • 9481
    Originally posted by bill1473 View Post
    What esc/ motor / prop combo would handle handle the 3 lipos? Had mine out yesterdat for the first time. It was cold!! As soon as i figure this out ill download vid and pics.
    stock these boats are fairly fast on 3s.
    what is your goal on 3s?
    • bill1473
      • Jan 2010
      • 46
      Dont have a goal yet. I just ordered x442 & x447 props. I just have an xtra set of lipos. And instead of goin to spend 300+$ on a set of new 4s lipos , may as well use three 3s i have. I found a small gps i had layin around. Still friggin cold out, but i found a spot thats not frozen. Ill start testin mph with my gps thurs morn. Im just really havin a hard time understandin this stuff and find it easier to use others knowledge and experiance. Ill try it and tell you if it works.
        • 9481
        try it stock and get your struts set correctly and have a blast with it, then start upgrading as you go..
        • forescott
          Hopelessly Addicted to RC
          • 3009
          Your motors will burn up on the 447. way too big. I burnt up a motor running the 442's everything was really hot!
          • bill1473
            • Jan 2010
            • 46
            #35
            No way! I already ordered them. Oh well , guess im gettin new motors next. Anyone have any sugestions? Were u runnin 3s lipos when they burned up? Im gonna play around with the struts.
            • forescott
              • 3009
              #36
              Another guy ran the 442's with good luck. I ran mine for about 2-minutes on 3s with the 442's and it got super hot. Took it home and one of the motors stopped working. Your call. Short run times and check the temps!
              • forescott
                • 3009
                #37
                I run the ammo 2700's with good luck. They will take 4s and get you into the mid 40's with a good prop. Another motor I want to try is the ARC 380 sized 2800kv 4-pole motors. Also fiegao has a long can 380xl motors in several kv ratings, and OSE has water jackets for them.
