Hey Guys just an FYI...
I have stock electronics and have been doing some testing/experimenting. I have the water cooling upgrades such as bigger tubing and dual inputs and bigger rudder. I have a sting strut with .78 wire drive and I did a GPS check with the stock plastic prop and got 48Mph and after that installed the Octura x442 and got up to 54.5Mph. This is in no way ground breaking numbers or shatering any speed records just wanted to put it out there for everyone.
The boat is running stable and running great with this setup. I had a little scare and thought I blew the motor, but it was just the collet on the motor that let loose. I had to tighten it up and the prop nut and I was good to go again.
That is it for upgrades with the stock electronics. Next I have plans for upgraded ESC , Motor and Props (HobbyWing 180 V3, CC1515 and Prather 215 220
I will repost once the other mods are done. I'm just going slow soI will do one component at a time starting with ESC. Also going to EC5 connectors
Have out there on the water!
