turnigy 180 esc programming problem!
  • Dominick
    • Apr 2015
    • 40
    I just got my new turnigy 180 and trying to program it with a card and all it does is beep!! is the card bad or something else wrong? It seams to work when I try and do it with the transmitter and beeps but not certain all is right that way. Please any info would be much appreciated. Thx
    Is this the one? http://hobbyking.com/hobbyking/store...r_Cooling.html
    You need a female to female servo wire to connect between the ESC and the program box. If you look closely, you will see a port where there are three exposed pins, that's the spot you hook up the special wire. This is the wire which I am referring to:http://www.kintecracing.com/ESC_s.html ( 3rd and 4th item down the page)
    The old version (V2) you could have connected directly between the ESC's wire and the program box, but not on V3.
