Seaking 180 amp esc
  • Wawalake
    • Jul 2014
    • 7
    Seaking 180 amp esc
    Just a question when programming this esc with two 3s batterys in series do you select 6s when using program card,Thanks
    Depends what you want to do with the ESC. For example: if you set the ESC to "Auto Calculate" then you let the ESC detect if it is 6s. OR, you can set the "Value" at 6 under "item2" on the prog. box. Note that the [ ] only applies to HV ESC, your 180ESC does not use those values. So it is "Value 6" on the prog. box when hooked to a 180 ESC.
