Throttle Control
  • Tripper
    • May 2014
    • 2
    Throttle Control
    Hey Guys.I have a question.Who is using the TQi at 50/50 and who at 70/30....What is the advantage or disadvantage of both
  • Spartanator
    • 1060
    70/30 you get more forward throttle room with less reverse room. 50/50 I run at that, not by choice but it works for me. If you run at 70/30 I would keep it that way... I just don't know how to change mine back, I am not very motivated to do it. "Don't touch it if it ain't broke" lol
    • PowerDemon
      • 353
      I run 70/30 just because I like the longer travel of the trigger. You will need to reprogram the ESC to switch back and forth between both settings.
      37" Fightercat Shocker powered by Neu 1530 on 10S
      • Tripper
        • May 2014
        • 2
        Thanks guys I no how to change the end points on the castle esc.Just wondering what everyone is using and why
        • Spartanator
          • 1060
          The 50/50 is used in the land based rc's from TRX, I may figure out out to change mine.
          • PowerDemon
            • 353
            In the Spartan manual pg 15 under "Setup Programming (Calibrating your ESC and Transmitter)" Is what you need to do to your ESC to change the throttle setting.
