Just picked up a modded spartan
  • SoFlaSpartan
    • Mar 2013
    • 55
    My lazy a$$ still hasn't gotten around to buying a high torque metal gear servo to test..... Poor boat is just sitting on it's stand collecting dust.
    • agentorange
      • May 2013
      • 238
      Are you having the same problem? I changed out the servo just havent had the time to get it into the water to test it out yet.
      • agentorange
        • May 2013
        • 238
        Ok guys an update on the steering problem. I went to the lake today after work and ran the boat and everything seems to be working much better with the new servo that i installed. Now my only problem is I have to change the cooling lines because one broke while driving the boat and flooded the hull. I got it back to shore under power before it got deadly but it was close.
        • Cooper
          • 1168
          Good to hear nothing got water fried!!! And good to hear the stronger servo is working. One more thing, do you have a lot of expo in your steering setup in radio? Sometimes that makes a boat feel really sluggish if its way up? Just a thought. I don't use much in a boat (unless saw stuff) but friend does and I thought his boat didn't turn, then he said just turn it more, I didn't like that but to each their own.
          • h8onit
            • Jun 2013
            • 9
            Agent what time did you go out. I was out there for a lil bit. Pming you my numbe.
            • agentorange
              • May 2013
              • 238
              I didn't have any expo in it that was one of the things I checked before I took the servo out. I thought like you maybe there was but they were all set to zero. h8onit I went to the lake at Academy Sports. I am going to try and go to the one off Ricker road on Friday after I get off work. I get off at 3 so I should be there around 330-345.
              • h8onit
                • Jun 2013
                • 9
                ok cool just give me a shout when youre headed there and Ill head up there I stay around the corner from the one ricker rd
                • agentorange
                  • May 2013
                  • 238
                  ok sounds good. I forgot that im going to go look at a new truck but I will text you and let you know if im going to be able to make it out there or not. It might be later in the afternoon.
