ESC programming instructions
  • mattig
    • Feb 2013
    • 1
    Hi does any body have the programming instuctions for the spartan esc? I got mine second hand but it did not have an owners manual. I took it for a run today and its slow which makes me think the esc is in traing mode?
    Thanks Matt
  • Niky
    • 62
    Hi Guys,
    I'd have one more question; the T180 ESC can work with Spartan's stock motor or it needs the 1600kv motor to function with no problem on 6s with the Octura x442?
    Thanks, salute all.
    Niky.
    • dag-nabit
      • Feb 2011
      • 775
      Yes to both.
      The owners manual is available on line at Traxxas.com http://traxxas.com/sites/default/fil...R01-130121.pdf
      Yes the T180 will work with the stock Spartan motor, I am assuming it is the Castle version 1800kv. Even with the T180, an 1800kv motor on 6S is on the edge. The X442 should be fine, I would be cautious about propping up much more on a 6S 1800kv setup.
      Kevin
      • Kramerr
        • 14
        On the same note, what settings should be programmed into the Castle Ice Hydra 240A ESC when being set up with the Castle software???
