Seaking 180 installation help please
  • Nutbar
    • Aug 2012
    • 43
    Hey, guys! I am about to order a Seaking 180 amp ESC and a Leopard 4082 1600kv motor. I am planning on using two 3s lipos connected in series for a total of 6s. I am also planning on using Traxxas connectors between the lipos and esc. My question is, what other wires/connectors will I need to install everything? I mean, will I need to order extra wire, or connectors, or what? I'm confused, and I don't want to get the new motor and esc, and then find out I don't have the right parts to even install them in my Spartan! Thanks in advance for all responses!
  • Make-a-Wake
    FE Rules!
    • 6057
    Do NOT use traxxas connectors......................5.5mm bullets minimum.
      Further more, if you use Traxxas or Deans, you need to make a Y for the series connection, ditch the idea with these connectors. Like Make-a-Wake said, in these applications, 5.5mm is considered minimum. And you will see how easy it is to connect the batteries to the ESC.
      • stadiumyamaha
        • 1371
        +1 the Traxxas handle the amp draw but are a pain in the butt to work with. The only good thing is you can buy an off the shelf y connector.
        Go with bullets. Super easy to work with.
        • KartRacer
          • Aug 2012
          • 363
          Nutbar
          Just going to throw my .02 cents in here. Go to 6.5 bullets, hardly any more money and when your hobby turns into crazy obsession your batteries are ready to go :)
          By the way they are available here at OSE and Steven takes real good care of his customers. Good luck.
          KartRacer ~ Dennis B
          Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
          • Kramerr
            • 14
            Even the EC3 connectors handle more current than the Traxxas connectors.
            • Nutbar
              • Aug 2012
              • 43
              Dude....no one has even answered my question yet. Here's my problem. I am a newb to all of this upgrading stuff. The stock esc has THREE WIRES. The Seaking 180 has TWO WIRES.
              1. Do I need to buy extra wire in order to make a series connection between the esc and batteries?
              2. If so, what SIZE/GUAGE wire do I need?
              3. Do I need to order bullet connectors for the esc to connect it to the motor?
              4. If so, what SIZE bullets do I need?
              5. So, I should use 6.5mm bullets to connect the esc to the lipos?? 5.5mm? 8mm?
              6. Could I use EC5's instead?
              7. Am I going to need to shorten any of the wires on anything?
              8. What is so wrong about using Traxxas connectors anyway? Does ANYONE use them in the Spartan w/upgraded motor/esc/prop?
              • stadiumyamaha
                • 1371
                You can use either 5.5 or 6.5 in that setup. Pick one and stick with it.
                You will need to put bullets on all three of the motor wires and on the esc side to the motor as well.
                If your running in series while using bullets just plug one neg battery cable to the neg side in the esc. Plug the pos of the second battery in to the pos of the esc and then connect the remaining wire on each of the batteries together.
                  Dood, no offense, if you were this clear, some of your questions perhaps would have been answered.
                  1. Is your Spartan new? Or did you buy from somebody and wanting to up-grade. ( Couldn't understand why you say there are three wires on the stock ESC)
                  2. Every ESC ( not talking those that have two wires for each pos. & neg.---Schulze or earlier CC ) has two sides, the one side with three wires gets to connect with the motor, the other side with two wires gets to connect with the battery(s). You say the stock ESC has three wires , assuming you are refering to the battery side, look closely and you will see there are only TWO wires---one red, one black coming out of the ESC battery posts. There is another jumper wire that connects (bridges) the two Traxxas plugs---that is what I said about the "Y" in my previous post which you will have to make if you so choose Traxxas plug. Any plug that has two polarities combined into ONE unit will need this laid out. Otherwise you would not be able to connect batteries in series config. having said that, I believe you can buy a ready made "Y" so if you solder the two wires to ONE SINGLE plug, it is possible to run your set-up.
                  3. I personally never use anything thinner than 10 gauge wire for motor-ESC connection, buy good quality wires, OSE has them.
                  4.Some motors come with 5.5 mm male, if you want to stick with the "minimum", then you need to get 5.5 mm female bullet to solder to the ESC's side which has the THREE wires!
                  5. EC3, Traxxas are fine for RC cars/trucks, boats have much higher amp draw, the demand is higher, ever see fireman using GARDEN HOSE??
                  6. I would not be able to tell you exactly how much/or if you need to shorten any wires. The shorter the more efficient and cooler it will run, but you need to determine that once you put everything in the hull.
                  • Nutbar
                    • Aug 2012
                    • 43
                    Ok. First, I want to apologize for being a little crotchety earlier. I'm just getting frustrated by all of the confusing, conflicting info on the internet about this topic. So, I think I have decided to go with 6.5mm bullets from the ESC to the lipos, and I now understand how to connect the ESC to the lipos in series. However, I still have a question about connecting the ESC to the motor.
                    1. Doesn't the motor come with bullets already installed?
                    2. If so, what size are the bullets?
                    3. If the motor bullets are a different size than 6.5mm, do I need to change them, or should I just put matching bullets on the ESC, so I can connect the ESC to the motor?
                    4. I read somewhere that u are NOT supposed to cut motor wires because they are "part of the wind". Is this true? Thanks again for everyone's help!
                    • Rocstar
                      Joel Mertz
                      • 1536
                      Match all your bullets to the motor to keep things simple, they typically come with them installed. 5.5mm is really all you need and it's best to not cut the motor leads as they are extensions of the motor windings on the Leo.
                      • stadiumyamaha
                        • 1371
                        If I remember correctly the leopards come with bullets to match the motor but they are smaller connectors.
                        I would put the 6.5 on the motor and esc while your doing the other side and batts. Just desolder the bullets off of the motor and re tin the wires using fresh solder and you'll be fine.
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          What do you mean by "the stock has three wires"? What part of the ESC has three wires? The T180 should have the exact same amount of wires, two on batt side and three on motor side.
                          • KartRacer
                            • Aug 2012
                            • 363
                            Was it used. Maybe someone took the motor wires off of the ESC. If so the tabs should be there. 5 wires total, no exception.
                            And I agree make all plugs the same size.
                            • Nutbar
                              • Aug 2012
                              • 43
                              Sorry for the confusion. There are only two wires from my stock esc to the lipos. What I meant by the "third" wire on the stock esc was the series "y" connecting "jumper" wire between the two connectors. When u get a Spartan, the esc, and everything else is hooked up already, which is why I bought it cuz I don't know much about boats and would rather spend more time using it than building it, but I want to run on 6s reliably, so I've decided to do the recommended motor/esc upgrade, but whenever I look at the pictures for the Seaking ESC, it appears to not have the same "three wires" like the stock one, so, consequently, I was confused about whether or not I was gonna have to buy extra wire, or if it came with extra wire, or what, which was, basically, my original question of this post along with not being sure if the esc came with bullets, and if not, what size bullets I would need that match the motor.
                              See, I didn't want to just order the motor and esc, and then get all excited when they arrived just to find out that I could not just "plug and play", and in fact, I should've ordered extra wires, extra/different connectors, and had a bunch of cutting, desoldering and soldering to do just to make everything work. I'm trying to be efficient, plan ahead, predict, and prevent future problems with this upgrade.
                              1. So, 6.5mm should work well all around, Lipos to ESC and ESC to motor?
                              2. If I am planning on using two sets of lipos, and 6.5mm all around, then that means I will need eight pairs of bullets total?
