Who's interested in a fibreglas spartan hull?
    • 9481
    Originally posted by Heaving Earth
    its still "voila" stupid…
    i just dont really like you…
    LAME
    DON'T EVER CALL AN OSE MEMBER STUPID ON THESE FORUMS!
    • JimClark
      • 5913
      Alright boys play nice now
      Billy Graham
      • Redddogg
        • 18
        Wow I started quite the "brew-ha-ha" lol. The les Paul design is made by practically every guitar manufacturer out there. The deep vee hull design is considered common place and no company can claim copyright to it. The top deck and hatch is the only part that could be considered "unique" and therefore fall under copyright law, I will change this to suit my needs and to prevent any infringement. As the moderators said please keep things civil, this is a hobby and supposed to be fun and foster friendships.
        • marksp
          • Aug 2011
          • 15
          Potentially interested :)
          • dag-nabit
            • Feb 2011
            • 775
            Besides being made of plastic, the Spartan hull has a couple other quirks that would be worth addressing. The chine walk is one, which I believe is due to the extremely steep vee of the hull. And a better strut design would be nice too.
            But, in answer to the original question, I would have interest in a quality designed and built FG hull that would fit the Spartan component tray.
            Kevin
            • Redddogg
              • 18
              Kevin
              I can address the angle of the vee once I get a plug made for the basic hull shape. This is my first attempt at this so the learning curve is going to be Steep. Being able to use the traxxas component tray is paramount. I'm also going to try to adjust the angle of the stuffing tube so it's more straight, and an aftermarket strut shouldn't be too hard to install as I'm going to use a 1/4" plywood transome. A dual rudder is a thought too. Currently im constructing a trailer for the spartan so the plug is on the back burner at least until it's done.
              • dag-nabit
                • Feb 2011
                • 775
                If it gets off the drawing board keep informed.
                Kevin
                • Redddogg
                  • 18
                  I will update and post pics as soon as I get going on this.
                    • Jul 2011
                    • 153
                    hi, will adding a the 2nd set of trim tabs closer to strut help get rid of chine walking on spartan??
                    • KartRacer
                      • Aug 2012
                      • 363
                      Yeh, probably would have an interest. Not many hulls in the length of the Traxxas. Seems as if it goes from 29 to 50ish. I am a traxxas fan in the car and truck arena.
                      KartRacer ~ Dennis B
                      Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
                      • Redddogg
                        • 18
                        In my unwashed opinion a second set of trim tabs won't help with chine walk. The chine walk on the spartan hull I think is due to the angle of the vee hull, it is too steep for high speed causing it to fall to port or starboard when on too high a plane. Adjusting the trim tabs down might put a temp bandaid on this by lowering the bow at mid to low high speed. I would like too see a shallower vee angle and another 1" or so of beam.
                        • Redddogg
                          • 18
                          I did this to my spare spartan hull tonight. It only took 20 min to disassemble it, and half of that was the battery tray. I used only a small flathead screwdriver. It was disturbing how easily the deck was separated from the hull.
                          • mrproc1
                            • May 2012
                            • 138
                            Hows the mold coming, any luck?
                            R.P
                            • Redddogg
                              • 18
                              Been busy with other projects lately. I am still in the process of smoothing out the imperfections and filling the factory holes. I'm getting back on this shortly. Next step it to mount it to a flange for the plug. The hull is pretty flimsy when disassembled so I need to stiffen the transom.
                              • iloverc83
                                • Feb 2013
                                • 72
                                How did this turn out?
