New Traxxas Spartan, question about run times.
  • Capt Dave
    • 56
    I'm running a Spartan with a stock motor and ESC and 5000 35C batteries. I am getting about seven minutes of run time if I don't push it too hard. Is that all I can expect for run times off these batteries or is the overheating sensor shutting it down? The boat doesn't quit running but slows down. When I got home I voltage tested the batts. One was 10.7 and the other 11.1. Am I missing something here? Thanks.
  • JimClark
    • 5913
    7 mins ia a long time
    Billy Graham
    • Make-a-Wake
      FE Rules!
      • 6057
      10.7v is completely depleted, in fact in my opinion its over-depleted, i like mine to read the nominal voltage of 3.7v per cell(11.1v on 3s) when the boat is brought in. 7 minutes is a LONG time as Jim pointed out....................so, no, you're not "missing" anything.
      • 26missgeico
        • Aug 2011
        • 63
        i get 10-15 with mine on max amps 6500mah 3s 150c batteries.. id say your doing pretty good!
        • siberianhusky
          • Dec 2009
          • 2206
          When you charge your batteries you shouldn't put more than 80% of the total capacity back into the battery, so your 5000mah packs should take a maximum of 4000mah to be fully charged. More than this and you are running your batteries down to far and will hurt the lifespan of the pack.
          I get about 3:30-4:00 runtime out of similar setups, batteries at rest then read about 3.7v per cell and take about 4000mah to reach capacity.
          I don't use the LVC in the esc, I time my runs based on charging data.
