Traxxas Spartan Speed Controller FIRE
  • sjp007
    • Sep 2011
    • 1
    Anyone had this problem or heard of this going on with the Traxxas Spartan Boat.. I have run this boat about 10 times with factory setup plus I added bigger tubing for the water cool system.. 2 lipos power edge 3 cell setup boat will run about 50 plus on smooth water.. But while running it the speed controller caught small fire and popped.. just wondering if anyone has seen this..
  • Rumdog
    • 6667
    Everyone that has owned one has seen this. There is a Traxxas section on this board with tons of info. Check it out.
    http://forums.offshoreelectrics.com/...shless-Q-amp-A
    • patte6596@rogers.com
      • Nov 2011
      • 85
      I too have a ESC that melted. Problem was likely 6s and a prop that was a little too big. Stay with the recommeded stock prop X442 or smaller.
      • LOVE6S
        • May 2012
        • 538
        I bought a new blue one and pluged in the batteries that came with it, not even 6s and the whole thing melted down, it would of caught fire if the connectors had not melted off, what a over priced peice of crap, I always wanted one, but I sent it back and got a refund. Anyone had a problem like this? I wanted to do a dry run to make sure it was gona work, after less than 60 seconds of a little throttle, it had a nuclear reaction.
        • jj2003
          HIGH VOLTAGE ADDICT!
          • May 2011
          • 1710
          Everyone has had the same issue. 6s is to much with a bigger prop, 5s is recommended. Should be covered under warranty.
          "If guns cause crime, all of mine are defective"
          45"Speedfreek
          , Fightercat #068 ​, MyYoutube Vids
          • jj2003
            • May 2011
            • 1710
            Did it have the Castle ESC with the caps built into it? Possibly a wiring issue?
            45"Speedfreek
            • LOVE6S
              • May 2012
              • 538
              I think so, it was the new castle verson, I really didnt even get a chance to really check it out in detail, I took it out of the box, put it on the stand, charged the batts, pluged them in, let it go thru its beeps, gave it a little throttle and it went up in smoke, it was a black melted mess.
              • LOVE6S
                • May 2012
                • 538
                the batteries melted too really bad.
                • LOVE6S
                  • May 2012
                  • 538
                  Anyway I dont want to mess up this guys thread, just wanted to say I had some problems too.
                  • jj2003
                    • May 2011
                    • 1710
                    Quite a few defective one's out of the gate after Castle revised them. Mainly motor issue's. Alot of guys have ripped out the O.E. stuff and gone with seking ESC's and NUE motors and a few TP power. Works like a charm! Sorry to hear about your bad luck. I too had similar with the old stuff and Traxxas warrantied them for the newer design. So far no issue's with the Nihm batteries. Havent tries Lipo's yet but my son uses it mostly now so the Nihm's are enough for him.
                    45"Speedfreek
                      • Nov 2011
                      • 85
                      Yes it is very disappointing. I have invested a lot of money for upgrades, and 3 sets of 6s and 3sets of 4s in batteries alone. I am too far in with the money I have spent. I will continue with the spartan. Call me a bugger for punishment. It is still the fastest RTR electric boat.
                        • Nov 2011
                        • 85
                        In regards to the using of 5s. It says in the manual not to mix different batteries. If so, do you think the warranty will still be covered?
                        • jj2003
                          • May 2011
                          • 1710
                          You can use a 2s and a 3s, but use the same MAH rating. 4S, 5S, 6S is fine, just keep the MAH the same. Your running the batteries in series not parallel so it doesn't matter.
                          45"Speedfreek
                          • LOVE6S
                            • May 2012
                            • 538
                            Does it matter if they have a diff c rating?
                              • Nov 2011
                              • 85
                              Thanks for the info on MAH. I didn't know that. Good Stuff. Al.
