my flex cable is done help please
  • Boss777
    • Jul 2011
    • 213
    also am i gona need that plastic tube ? or just install it in that coper one without it? if i get that .187 from Jeff's store ?
    • dag-nabit
      • Feb 2011
      • 775
      If you go with the .187 cable you won't need the teflon liner, the larger diameter cable won't fit with the liner installed. Just keep it greased up good.
      If you go with the .078 wire drive, then you should put in a new piece of liner.
      Kevin
      • Boss777
        • Jul 2011
        • 213
        Kevin
        thanks the coper one called traxxas and they said they will send me one
        but i need need that .078 also how do i mount the flex cable to shaft ? do i use glue or something?
        • Boss777
          • Jul 2011
          • 213
          i need need that .078 also how do i mount the flex cable to shaft ? do i use glue or something? if so what kind where can i get it ?
          • dag-nabit
            • Feb 2011
            • 775
            The shaft will come mounted to the flex cable or wire drive. Be sure to order the correct collet to fit the flec cable or wire drive you choose.
            Kevin
            • Boss777
              • Jul 2011
              • 213
              i just got coper tube from traxxas and i need stock flex now any one has one?
              • rlpowley
                • Sep 2011
                • 1
                I need to get a .078 wire drive for a 3/16 prop from Jeff Wohlt. Does anyone know how to reach him? Thanks!! Rob
                • 1truckerdan
                  • Aug 2011
                  • 344
                  Fighter cat has them in stock for less than $15
                  You have to sign in to see the prices
                  When you know it all.......you never will learn anything new
                  • Rcforever27
                    • 240
                    You can try that or try www.wohltsrcboats.com....
                    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
                    • Boss777
                      • Jul 2011
                      • 213
                      email him i did and he resonded but the pars i need is .078 to for spartan
                      • Boss777
                        • Jul 2011
                        • 213
                        i just called one of the site and they have one in stock the original traxxas spartan flex and shaft and they said they are recall they been defective and now traxxas make new once
                        i need help hear i got original flex cable and it came out from shaft does any one knows what glue to use or welder
                        • martin
                          • 2881
                          Most shafts that are bonded are done with Loctite 603, A few use Loctite 638 that has a slightly stronger bond but is not oil tolerant.
                          • Rumdog
                            • 6667
                            Just buy a .187" cable from OSE and be done with it..
                            • Boss777
                              • Jul 2011
                              • 213
                              i want to but then i need to get that mount that goes on motor and probable drip out holles which i dont want to do it couse i might use different flex in the future
                              • Boss777
                                • Jul 2011
                                • 213
                                coupler is what its called or will .187 work with original coupler ?
                                i don't mind drilling bigger holes
