have had a few spartan boats and they wont steer at all---check the trims and end point and also reset the radio---they rudder steers only like maybe 5 degrees--also tried a new servo and same thing---i go desperate that i put in a aftermarket servo saver to at least get like 10-15 degress turn radius--anyone else having issues.
spartan-steering issue
A quick re-read of your original post and I see you have already tried most of the usual suspects. And you say you have had more than one Spartan doing the same thing?
I was going to suggest trying a different receiver, but if you have had this same problem on more than one boat, it is unlikely that will help.
When you say 5* turn radius, do you mean the rudder only moves 5* left or right of center, or do you mean when you are running the actual turn radius of the boat is only about 5*?
My Spartans do not turn nearly as well at very low speeds as they do at higher speeds. At high speeds it is easy to over steer.
Kevin
