Should i run the traxxas Teflon liner with a wire drive? I have a .187 flex drive on my other Spartan , and I'm not running one i'n that.... But i wasn't sure if i should with a wire drive setup... Thanks i'n advance....
Wire drive question....
Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Tags: None
Sure...use the stock liner...it has plenty of room but will keep the wire a bit cooler and quiet.
Ok thanks...Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
Yup, I just got my wire drive from Jeff the other day and I run it with the stock liner, I put 2 runs on it and after the second one I pulled it out, and there was still some grease left, and it wasn't all black and nasty like on the stock one.
I like to sand the wire with some 320 and then use some metal polish on them...very smooth and resists rust much better
Sounds good I'll have to try that ... Still waiting for my bare hull to come off backorder.... This waiting is killing me.... I guess I'll just run my other Spartan for now while i wait lol... Thanks again!Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
glad to hear it ebomb. they work in about anything if built right
