once a spartan always a spartan. leopard. yes now i can move on..
  • electric007
    • Jul 2011
    • 53
  • Rcforever27
    • 240
    I was told venom lipos aren't good for this boat. It pulls too many Amps.... I myself have 4 venoms and stopped using them when i found tht out... Go on hobbyking.com and look for turnigy lipos ... 4000's or 5000's they have like a 40 or 45 c rating.... I have 4 4000's and love them... They are made for boats as they have 10 gauge wiring instead of 14 or 16 gauge..... Good luck ! Keep us posted!Also a couple guys on thus forum informed me that venom packs advertise the c ratings as say 40c but supposedly that's not accurate.... Turnigy lipos are rated i'n actual c ratings .....
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
    • Rcforever27
      • 240
      Also not sure if you're new too eletric boating , but boats pull about the same as a car does but the difference is boats "pull" the amps more continuous than cars.... Thus heating things up more, and quicker ....
      • electric007
        • Jul 2011
        • 53
        ok thanks.. i am new to electric boating.. and i will check out hobbyking..
        • Rcforever27
          • 240
          Good luck ! Check back here tomorrow and see if some other people post ... I kno "dag -nabit " is very informative and might have more answers than myself ... Happy boating and welcome too it....
          • electric007
            • Jul 2011
            • 53
            ok. thanks will do.. and averything still works. motor and esc..
            • dag-nabit
              • Feb 2011
              • 775
              Thanks for the kudos Scott, however I'm not sure they are entirely deserved
              I'm probably not the most informed person for this particular problem, lipo batteries are still pretty new to me as well. Brushless55 or Diesel might be more experienced in this type of failure.
              Apart from a dead short only a few things come to mind: 1. what was the C rating on the batteries. 2. Were the batteries balance charged. 3. How old were the batteries. 4. LVC not working or ignored.
              Too low of a C rating will result in too much internal resistance under high load and resistance causes heat (should be minimum 30C on 5000mah batts)
              If the batteries aren't balance charged one cell could be at a lower voltage than the rest and could become over discharged which can cause a failure.
              Resistance increases in the cells as they age, old batteries could fail due to overheating caused by high resistance.
              If the LVC isn't cutting in, or if you continue to run longer than it takes to run the boat to shore, you can over discharge the packs and have a failure.
              Regardless the reason, it is a shame to see this damage to your boat.
              Kevin
              • electric007
                • Jul 2011
                • 53
                20c count. 30c burst. and yes they say they were balance. but one of the times it didnt. one of the cells was at 000. and it was not in the battery the fried. lvc was just under 3.8..
                batteries were 2 1/2 weeks old. ran @ least once a day.. i did notice issues. with it. once the new setup was put in. it would not last 1min before it cut off.. new batts on the way. looking for new hull. motor esc still work. but then i think my esc might have a tic in it. probably should get another just incase.. it was a very good setup and very fast.
                time to barry this hull.. or fram it.. lol!!
                • Savage Skidoo
                  • May 2011
                  • 312
                  Finnally got out on the new up-dated stock replacements for the spartan , 2 3s-5800 30c lipos and all stock waiting for OSE parts to arrive . WOW no isues :) ....yet , Thanks too all the testers here , ran my first two full packs .
                  www.facebook.com/Boaters and Crawlers Durham
                  Durham Off Road Rc Club - www.dorc.ca founding member
                  • dag-nabit
                    • Feb 2011
                    • 775
                    Most likely the source of your problems, too low C rating for this setup.
                    If the batteries can't discharge fast enough due to internal resistance they will heat up on you. Voltage can also drop which could explain the LVC kicking in early.
                    Try e-bay for a hull, I picked one up for $99 and it included the hatch. I also saw a couple on there for $230 that included all the hardware and the component tray, not sure how much damage you need to address.
                    Kevin
                    • Flame On
                      • 36
                      I have the Venoms. I've got two 2S and 4 3S but all mine are 50C. Now you've got me concerned about running the Venoms.
                      Should I sell these off and pick up the Turnigy's?
                      Also, LHS told me no Lipo's are waterproof except for one brand (can't remember name) but they were SUPER expensive. I'm not going to lie, I get myself into the "nose up death bob" sometimes. As far as the batteries go, how concerned should we be about that?
                      Anybody ever put styrofoam against the transom to help keep the rear up too?
                      • Flame On
                        • 36
                        Kevin
                        Sorry if dumb question but I'm still kinda a newbie, but.... I've got the Venom Pro Charger. I tried to balance charge my 3S for the first time last week. When I checked on the charger after watching a movie one night... the charger was still running after 2 hours and 40 min. I figured I didn't set it right. Batteries weren't even warm to the touch, but been afraid to do it again. Since, I put it on Balance charge and have it show me the voltage for each cell, I see them even up to about the same within about 30 seconds. Then I cancel that and put it on regular charge. Usually takes 45min to 1:15hr. That about normal?
                        • dag-nabit
                          • Feb 2011
                          • 775
                          I have never run Venom Lipos but have a stack of Venom nimh batteries at home and they have been decent batteries. If you are running 50C rated batteries, and not having problems with them running hot, I wouldn't worry too much about them being Venom brand. It doesn't matter what product you talk about you can always find someone who says brand X is crap because they have had bad luck with that brand. You can also find someone who will swear that brand X the best brand on the market because they have had nothing but great luck with them.
                          Most batteries aren't water proof, but don't worry about it too much, simply getting them wet won't hurt them. If they get soaked, you do need to make an effort to drain as much water as possible out of the sleeve and allow them the opportunity to air dry well. If you store them wet or damp the connections will rust/corrode prematurely.
                          Some pieces of pool noodle, or pipe insulation foam, fitted in along the sides is not a bad idea. it can help keep your batteries in place and provide extra floatation. Taping the hatch also works great, we always tape our hatches and have never had one pop off, and when we flip the boat just floats with very little water getting inside. (note: I modified the back of hatch by removing the two tabs that stick out, this makes it easier to tape securely)
                          Kevin
                          • dag-nabit
                            • Feb 2011
                            • 775
                            I'm not familiar with that particular charger, but I'm going to assume the basic function of lipo chargers is similar.
                            First. The time it takes to charge a battery is dependent on many factors, but most notable is the output amperage of the charger. if you have a 5000mah hr (5 amp hr) battery, and your charger outputs at 5 amps charge rate, it will take 1 hr to charge a fully discharged battery. In reality it will take less time because your lipo battery should never be fully discharged if your lvc is working correctly.
                            So your 45 min to 1:15hr charge time sounds pretty normal, and probably is, but without knowing the size of your batteries and the output of your charger, we can't be certain.
                            The charger I have can be connected to a computer and you can graph the charge cycle. I have observed, depending on how "off balance" the cells are, that the balance cycle can be fairly quick (only a few minutes) to fairly lengthy (30-45 minutes).
                            Watching the trend during balancing, if the cells are way off balance, the charger cycles between charge mode and discharge mode as it brings the cells into a balanced voltage state. In other words, it discharges to drop voltage in cells with higher voltage readings, then charges to bring lower voltage cells up to balanced voltage.
                            It does this slowly over many cycles.
                            I would say have faith in your charger and give it the time to do it's thing.
                            Also, I have often seen it recommended that you only have to balance charge every 3 - 5 charge cycles. I balance charge my batteries every cycle. I find if I do the balance cycle usually only takes 3-5 minutes longer (on my charger) and with the way boats draw juice, I think it is good practice to keep the batteries always in close balance.
                            Kevin
                            • Flame On
                              • 36
                              Dag - Great stuff! Exactly what I need. I appreciate your quick response and expertise.
