Spartan 6s motor?
  • Rcforever27
    • 240
    Spartan 6s motor?
    Gonna build another Spartan with 6s lipo.... Leopard 1800kv? Or 2000 kv motor? Will have all the cooling upgrades and mods.... Thanks i'n advance!
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
  • dag-nabit
    • Feb 2011
    • 775
    Personally I wouldn't go over 1800kv on 6S. Just too many RPM's and additional amp draw, which translates to too many headaches, IMO
    But it's just that, an opinion.
    Have fun with the build.
    Kevin
    • Rcforever27
      • 240
      Thanks Kevin i agree just wanted to hear it from a veteran boater ..... 2000kv, is that alot higher rpm? Or is it a minuscule amount more? And will a seaking 180 work or should i try a castle 160 or 200 or even the 240 Ice escs?Thanks ...
      • dag-nabit
        • Feb 2011
        • 775
        Well 6S is 22.2v nominal, so every 100kv extra on the motor gives you 2220 extra RPM
        1800 x 22.2 = 39,900 unloaded RPM
        2000 x 22.2 = 44,400 unloaded RPM
        Compare that to the the stock 1600kv motor on 6S @ 35,520 RPM you are almost 9000 RPM more than stock with a 2000kv motor.
        Consider that around 30,000 RPM is the recommended max for sport boating.
        Also the higher the kv rating, the more amp draw, so your risk of overloading the electronics increases as well. (running a separate battery pack for your Rx and Servo can help)
        Kevin
        • Rcforever27
          • 240
          Ok thanks kevin gonna print this info.... Very valuable....
          • Snowride
            • 297
            I am extremely satisfied with my Tacon 1700. Cheap and makes the Spart scream. Some say it is a rebadged Leopard but who knows? For $45 it is truly well worth it.
            • Rcforever27
              • 240
              Yeah i hear ya I'm gonna look into it....thanks!
